Старый 02.03.2016, 16:11   #1
kurthatlevik: AX RTW – Hack to enable configuration mode
Источник: https://kurthatlevik.wordpress.com/2...guration-mode/
When downloading the AX RTW local VM from connect, you often want to disable some configuration keys. (Like catch weight etc). But now you will see the following warning;
“This form is read-only unless the system is in the maintenance mode. Maintenance mode can be enabled in this environment by running maintenance job from LCS, or using Deployment.Setup tool locally”
This warning is to prevent that configurations are enables/disabled, and that the system is set in maintenance mode. There are 2 ways of dealing with this.
  1. The proper way; Use the Microsoft.Dynamics.AX.Deployment.Setup.exe command; (Credits to Joris de Gruter)
    Run this from command line:
    c:\packages\bin\Microsoft.Dynamics.AX.Deployment.Setup.exe –metadatadir c:\packages –bindir c:\packages –sqlserver . –sqldatabase axdbrain –sqluser AOSUser –sqlpwd AOSWebSite@123 –setupmode maintenancemode –isinmaintenancemode true
    and then run the command with “false” at the end to turn if back off.
  2. The Hack way; Use the Microsoft SQL Server Management Studio, and edit the following record in the table dbo.SQLSystemvariables ; CONFIGURATIONMODE
After that, you can change configurations. But make sure you never
EVER do this in a production environment!
Hacking DAX’ing J
Rahul Sharma: Dynamics AX 2012 R3 Mobile Apps Configuration Using Self-Signed Certificate Blog bot DAX Blogs 0 05.05.2015 08:14
kurthatlevik: Turn your Dynamics AX WMS from ‘Where’s My Stuff’ to an actual ‘Warehouse Management System’ Blog bot DAX Blogs 0 21.11.2013 19:11
Часовой пояс GMT +3, время: 08:03.
