Старый 11.01.2016, 22:12   #1
emeadaxsupport: Standard cost rounding adjustments posted as at system date and not as at the transaction date
Источник: https://blogs.msdn.microsoft.com/axs...nsaction-date/
    There are many reasons why a customer may need to backdate an inventory transaction e.g. when a count journal is created, if it takes more than a day to count the stock, the journal cannot be posted that same day.     This backdating will produce a financial voucher with two different dates... Read more
emeadaxsupport: View a full breakdown of cost per item using the Inventory Value Statement with Standard Cost Breakdowns report in Dynamics AX Blog bot DAX Blogs 0 01.05.2015 01:12
emeadaxsupport: The error message "The transactions on voucher XXX do not balance as per [date]. (accounting currency: 50,00 - reporting currency: 50,00)" in open customer transactions settlement Blog bot DAX Blogs 0 13.10.2014 21:11
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
axinthefield: Standard Cost in AX 2009 Blog bot DAX Blogs 0 02.06.2011 00:11
emeadaxsupport: Kerberos authentication does not work when Enterprise Portal uses a non-standard port Blog bot DAX Blogs 0 14.02.2011 21:11
Часовой пояс GMT +3, время: 18:20.
