Старый 04.06.2015, 19:12   #1
emeadaxsupport: How to Install the Dynamics AX Enterprise Portal in a Load Balanced SharePoint farm in 4 simple steps
Источник: http://blogs.msdn.com/b/axsupport/ar...ple-steps.aspx
(Please note this article assumes you have working knowledge of SharePoint, IIS, DNS and host files)
1. Create a new Web Application on the SharePoint Central Administration Server. This Web Application URL should point to the common name or Network Load Balanced (NLB) name.
2. Modify the host file found in '\windows\system32\drivers\etc\hosts' on each node
  • Point the NLB name to the IP of the local server. Example: 192.168.1.100 epportal
  • Flush DNS after any change to the host file by opening a command prompt as Administrator and running: ipconfig /flushdns
3. Pick one node in the Farm and run the Enterprise Portal installer.
  • During the install, select all 3 checkboxes in the 'Configure a Web site for Enterprise Portal' step to configure the Windows SharePoint Services, Create Web Site, and Restart IIS.
  • Verify Enterprise Portal renders successfully on this node before moving forward by opening Internet Explorer and browsing to the host header name specified in the creation of the Web Application. Example: http://epportal
4. On the other nodes, run the Enterprise Portal installer and select only the first and third checkbox in the 'Configure a Web site for Enterprise Portal' step as shown below
After following these steps each node should be able to successfully render Enterprise Portal locally when browsing the NLB name.
Thanks to contributor James Wang
sharepoint
axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010 Blog bot DAX Blogs 4 16.10.2017 17:50
emeadaxsupport: Sample steps on installing and configuring SharePoint 2010 and deploying AX 2009 Role Centers and Enterprise Portal Blog bot DAX Blogs 0 14.02.2011 21:11
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
Часовой пояс GMT +3, время: 01:42.
