Старый 27.01.2015, 12:11   #1
DynamicsAxSCM: New white papers for TMS
Источник: http://blogs.msdn.com/b/dynamicsaxsc...s-for-tms.aspx
We would like to inform you that two new white papers for TMS are made available today.
Transportation management engines
The Transportation management system (TMS) module includes a number of extension points called engines that let you implement custom algorithms to perform tasks that are related to the rating of transport and freight reconciliation. The purpose of this document is to describe all transportation management engines available in Microsoft Dynamics AX 2012 R3. The document is intended for implementation consultants and users who want to analyze the transportation situation at a company and perform the setup that is required in order to use the TMS engines in Microsoft Dynamics AX 2012 R3. It explains the architectural background of the engines and the relation between the different types of engines. It also describes the initialization and metadata configuration that is needed.
You can download it from PartnerSource or CustomerSource.
Outbound transportation planning and execution
This white paper includes a demonstration script for a typical order-to-cash flow that includes outbound transportation planning and execution, and advanced warehouse management operation, as part of the order fulfillment process.
crminthefield: Microsoft Dynamics CRM 2015 White Papers & Technical Documentation Blog bot Dynamics CRM: Blogs 0 05.01.2015 19:11
crminthefield: Microsoft Dynamics CRM 2013 White Papers & Technical Documentation Blog bot Dynamics CRM: Blogs 0 27.12.2013 09:11
axsdkupdates: Code Upgrade White Papers Describe New Patterns for Development in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 03.08.2013 04:29
DynamicsAxSCM: Dynamics AX 2009 Cost Accounting White papers Blog bot DAX Blogs 0 02.12.2011 20:14
DynamicsAxSCM: Microsoft Dynamics AX 2012 SCM White Papers: Code Upgrade Blog bot DAX Blogs 0 12.04.2011 08:11
Часовой пояс GMT +3, время: 04:14.
