Старый 01.01.2015, 02:28   #1
palleagermark: Testing JSON from AX 2012
Источник: http://www.agermark.com/2015/01/test...m-ax-2012.html
I wanted to see how JSON could be consumed from AX, and found this great article from Jonathan.
Then I needed something to test with and found the site jsontest.com.
And so, here are two examples.
The first example just returns your IP address:
static void JSONTestIP(Args _args)
    RetailWebRequest    request;
    RetailWebResponse   response;
    str                 rawResponse;
    Map                 responseData;
    str                 responseValue;
    RetailCommonWebAPI webApi = RetailCommonWebAPI::construct();
    request = RetailWebRequest::newUrl("http://ip.jsontest.com");
    response = webApi.getResponse(request);
    rawResponse = response.parmData();
    responseData = RetailCommonWebAPI::getMapFromJsonString(rawResponse);
    responseValue = responseData.lookup("ip");
    info(strFmt("Element name: %1", responseValue));
The next example returns key/value pairs. In this example first name of a person is found based on the persons last name:
static void JSONTestKeyValue(Args _args)
    str                 rawResponse;
    Map                 responseData;
    str                 responseValue;
    request = RetailWebRequest::newUrl("http://echo.jsontest.com/Agermark/Palle/Kent/Clark");
    responseValue = responseData.lookup("Kent");
Последний раз редактировалось mazzy; 12.01.2015 в 21:33.
palleagermark: Exporting models from AX 2012 with .Net Runtime version 2.0 Blog bot DAX Blogs 1 05.12.2013 14:37
palleagermark: Microsoft Dynamics AX 2012 R2: How to upgrade from an earlier release of Microsoft Dynamics AX 2012 (Poster) Blog bot DAX Blogs 0 17.04.2013 10:11
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
Часовой пояс GMT +3, время: 14:13.
