Старый 16.12.2014, 19:11   #1
emeadaxsupport: How to prevent copy/paste from grids
Источник: http://blogs.msdn.com/b/axsupport/ar...rom-grids.aspx
In Microsoft Dynamics AX you can copy information from grids and paste that information into a Microsoft Excel worksheet. You can do this by selecting the lines you want to copy, going to File > Edit > Copy, and then pressing CTRL + V in Excel. You can also just press CTRL + C from the Dynamics AX grid.
For some customers this is extremely useful, for some other customers this can be something they don't want the users to be able to do. And there is no way to control this functionality through standard Dynamics AX security.
Following is an example of customization you can test to block this functionality for all users.
Class: sysSetupFormRun
Method: task
First, declare a variable of type FormControl, and then add the if code block for #taskCopy:
I hope this is helpful!
Bertrand
emeadaxsupport: How to copy a budget to a new budget in AX 2012 using Excel Add-in Blog bot DAX Blogs 0 27.11.2012 15:11
emeadaxsupport: How to delete orphaned data remained from deleted company? Blog bot DAX Blogs 0 09.12.2010 16:11
Dynamics AX Sustained Engineering: How to prevent transaction reversal from posting to closed dimensions Blog bot DAX Blogs 0 22.04.2010 23:05
emeadaxsupport: How to open an AX form from your own help Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 01:37.
