Старый 01.11.2014, 04:41   #1
lcs: Workaround: "An unexpected client error has occured"
Источник: http://blogs.msdn.com/b/lcs/archive/...ured-quot.aspx
If you receive the below error while using LCS please try again after clearing the browser cache.
emeadaxsupport: "Unexpected error" when running a pop up on the Enterprise Portal for the first time Blog bot DAX Blogs 0 06.07.2011 17:11
Event ID: 110 и Event ID: 117 Object Server 01: The database reported (session 1 (-AOS-)): [Microsoft][SQL Native Client]Communication link failure. The SQL statement was: "" Poleax DAX: Администрирование 0 18.05.2011 17:08
emeadaxsupport: Running AX 2009 Client raises error: "An invalid directory structure for Microsoft Dynamics AX was detected" Blog bot DAX Blogs 0 01.04.2011 06:13
"An unexpected exception occurred" во время установки. Hub DAX: Администрирование 2 19.12.2009 12:09
gatesasbait: Something to check if the Dynamics Ax 4 client throws the "failed to logon to axapta" error Blog bot DAX Blogs 0 08.09.2008 19:05
Часовой пояс GMT +3, время: 14:15.
