Старый 28.02.2014, 01:11   #1
atinkerersnotebook: Save Document Attachments To SharePoint
Источник: http://atinkerersnotebook.com/2014/0...to-sharepoint/
Originally posted on Dynamics AX Tip Of The Day:
The document attachments function within Dynamics AX is super useful, but if you don’t want all of the files that you attach cluttering up your database, or stored away on a local file share, there is another option available. You can save them off to SharePoint. This also has a side benefit of allowing you to take advantage of the features of SharePoint such as document control, versioning, and also workflow if you like to manage the processing of the attached documents.
View original
atinkerersnotebook: Copy Document Attachments From One Record To One Or More Other Records Blog bot DAX Blogs 0 24.02.2014 22:13
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Часовой пояс GMT +3, время: 14:08.
