Старый 18.02.2014, 19:11   #1
emeadaxsupport: Project ID in a Purchase order header level or line level- it is not possible, Project ID field is greyed out
Источник: http://blogs.msdn.com/b/axsupport/ar...reyed-out.aspx
There could be a situation in AX2012 when you have created Purchase order and saved it (Project ID is unknown in this stage). After that if you want to enter Project ID to a header level or line level- it is not possible, Project ID field is greyed out.
The conclusion of this behavior is that this is how project Purchase order is currently designed:
- The Project ID on the PO header shouldn't be editable when a PO header is created without a project.
- The Project ID on the PO header will only be editable when a PO header is created with a project. The project ID on the PO header also cannot be cleared when a PO header is created with a project.
This design is done due to some consequences changing project ID in Purchase order.
ax2012
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Часовой пояс GMT +3, время: 13:37.
