Старый 31.01.2013, 19:11   #1
axaptacorner: SQL Server 2012 compatibility error in AX 2012
Источник: http://axaptacorner.blogspot.com/201...n-ax-2012.html
FastFirstRow and compatibility error in AX 2012 with SQL Server 2012:
Hi friends its good news to launch SQL Server 2012 but it is compatible only for the AX 2012 R2 for the earlier version it thows compability error as-
Error: can not select a record in application model.The SQL database has issued an error.
"FastFirstRow" is not recognized table hint option. it is intended as a parameter to a table-valued function or to changetable function.ensure that your database compatibility mode is set to 90.
So if you got above error you have to install hotfix KB2680186 launch by microsoft.
Note: Ensure that you have taken full backup before apply hotfix.
Happy DAXing !!!
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
Проблема с компиляцией AX 2012 Feature Pack 6.0.947.280, MS SQL Server 2008. saygon DAX: Программирование 7 29.05.2013 13:12
addicted2ax: Dynamics AX 2012 & SQL Server 2008R2: Cross Join vs. Inner Join – Houston we have *NO* Problem Blog bot DAX Blogs 0 20.12.2012 20:11
emeadaxsupport: Unable to deploy AX 2012 Reporting Extensions on SQL Server 2012 Reporting Server Blog bot DAX Blogs 0 26.06.2012 23:12
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
Часовой пояс GMT +3, время: 19:52.
