Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 27.01.2013, 22:18   #1
Kent is offline
Kent
Two datasources, two grids
Hi,
I have two tables: t1 (main table), t2 (related table).
I should show on form only t1 and t2 records, where for t1 related t2 records exist,
Normaly I could use InnerJoin, but I have two grids: t1, t2.
I tried:
1. InnerJoin shows the same count of resords for t1, how much records exists for t2.
2. OuterJoin return all t1 records, even related records not exist in t2
3. ExistJoin return correct redords for t1, but records without values for t2.
Is here some solution?
daxmusings: Forum: Advanced Display Method Querying Joined Datasources Blog bot DAX Blogs 0 11.10.2011 09:11
Методы таблицы в DataSources (DAX4) Qaz Qwerty DAX: Программирование 2 16.06.2008 10:11
Refreshing DataSources on Form Blog bot DAX Blogs 3 07.05.2008 23:09
Kashperuk Ivan: Find all reports with datasources innerjoined 1:n Blog bot DAX Blogs 2 09.03.2008 14:05
Drag and Drop grids из одной формы в другую Sveta1978 DAX: Программирование 2 11.12.2007 18:46
Часовой пояс GMT +3, время: 03:28.
