|  23.11.2012, 23:13 | #1 |
| Участник | sumitsaxfactor: Replace a Financial Dimension in Default Dimensions–Condensed [AX 2012]
			Источник: http://sumitsaxfactor.wordpress.com/...ensed-ax-2012/ ============== In my previous post on Replacing default dimensions, I had provided a job to replace one financial dimension within a default dimension. The job was pretty big and I always thought that Microsoft should have provided some way to do these operations easily. Luckily I found a class that has helped me to condense that job and make it pretty small. I am sharing that job here: The dimensions for Customer record looks like this before running the job:  Here is the job to change the values. We will change the values for Business Unit, Department and Worker all with this simple job: staticvoid replaceDefaultDimensionsCondense(Args _args) { /* * In this job, we will replace the Business Unit Value from BU-001 to BU-002 * and fill in the values for Department as Dep-001 and Worker as 114 */ CustTable custTable = CustTable::find(‘CUS-00004′); //Customer Record containing Financial Dimension Struct struct = new Struct(); //Structure to hold the dimension values to replace container defDimensionCon; //Container to prepare the required values and dimension attribute combination DimensionDefault dimensionDefault; //Get the replaced dimension recid DimensionAttributeSetItem dimAttrSetItem; //Table to get active dimensions for the legal entity DimensionAttribute dimAttribute; //Table to get the Financial dimensions int i; //For looping //Loop for required dimensions whileselect Name, BackingEntityType from dimAttribute where dimAttribute.BackingEntityType == tableNum(DimAttributeOMBusinessUnit) || dimAttribute.BackingEntityType == tableNum(DimAttributeOMDepartment) || dimAttribute.BackingEntityType == tableNum(DimAttributeHcmWorker) && dimAttribute.Type != DimensionAttributeType::DynamicAccount join dimAttrSetItem where dimAttrSetItem.DimensionAttribute == dimAttribute.RecId && dimAttrSetItem.DimensionAttributeSet == DimensionCache::getDimensionAttributeSetForLedger() { //Add the Dimension name and display value to struct if (dimAttribute.BackingEntityType == tableNum(DimAttributeOMBusinessUnit)) { struct.add(dimAttribute.Name, ‘BU-002′); } elseif (dimAttribute.BackingEntityType == tableNum(DimAttributeOMDepartment)) { struct.add(dimAttribute.Name, ‘DEP-002′); } elseif (dimAttribute.BackingEntityType == tableNum(DimAttributeHcmWorker)) { struct.add(dimAttribute.Name, ’114′); } } //Prepare the container defDimensionCon += struct.fields(); <span><font face="Consolas"><font size="2">for (i = 1<font color="#000000">; i
				__________________ Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
