Старый 19.10.2012, 21:12   #1
ax-erp: How to import xpo in axapta by code
Источник: http://microsoft-dynamics-ax-erp.blo...a-by-code.html
How to import xpo in axapta by code. You can write following code in job or any even where you want to import
SysImportElements ElementToImport = new SysImportElements();
ElementToImport.newFile("D:\\TestProject.xpo");
// XPO filename which may be project,form,report or any thing from aot
ElementToImport.parmImportAot(true);
ElementToImport.parmImportWithIds(false);
ElementToImport.import();
ax-erp: How to Set the Query Range on a SSRS Report Blog bot DAX Blogs 0 18.10.2012 19:11
ax-erp: How to use default dimensions as Dialog fields in dialogs [Dynamics AX 2012] Blog bot DAX Blogs 0 19.09.2012 20:11
ax-erp: How to build form by code Dynamics AX 2012 Blog bot DAX Blogs 0 24.07.2012 21:12
ax-erp: How to filter records in a form by code Blog bot DAX Blogs 0 13.06.2012 16:11
axaptacorner: Import XPO With Code Blog bot DAX Blogs 1 15.09.2011 17:57
Часовой пояс GMT +3, время: 02:55.
