Старый 06.09.2012, 18:11   #1
axblog4u: Tip: COMVariantType for Real values in Dynamics AX
Источник: http://axblog4u.wordpress.com/2012/0...n-dynamics-ax/
<span style="font-family:'Trebuchet MS';color:#204063;font-size:10pt;">
Case Study: Reading cell content from excel template for COM variant type VT_R4 or VT_R8 is always little tricky.
Observation: Reading real value can be done in following ways
1) num2Str0(_variant.double(), 0);
2) num2str(_variant.double(), 0, numOfDec(_variant.double()), 1, 0);
Here is the output which is generated where the first function value is always a round-off value compared with the second function which returns the exact content with correct scale and precision.
COMVariantType Functions output for Real values.
/* Build excel template as following and specify the path @ excel=======================================Column Integer Real =======================================Rows(1) 123 60.9756097560976Rows(2) 234 5.69105691056911=======================================*/static void SR_VariantType(Filename excel = @'C:\Projects\Data.xlsx'){ int rows; int columns; COMVariant variant; SysExcelCells sysExcelCells; SysExcelWorkbook sysExcelWorkbook; SysExcelWorkbooks sysExcelWorkbooks; SysExcelWorksheet sysExcelWorksheet; SysExcelWorksheets sysExcelWorksheets; SysExcelApplication sysExcelApplication; str variant2Str(COMVariant _variant) { str valueStr; ; switch(_variant.variantType()) { case COMVariantType::VT_EMPTY : valueStr = ''; break; case COMVariantType::VT_BSTR : valueStr = _variant.bStr(); break; case COMVariantType::VT_R4 : case COMVariantType::VT_R8 : if(_variant.double()) { valueStr = strFmt("@SYS311964", num2Str0(_variant.double(), 0), num2str(_variant.double(), 0, numOfDec(_variant.double()), 1, 0)); } break; default : throw error(strfmt("@SYS26908", _variant.variantType())); } return valueStr; } ; sysExcelApplication = SysExcelApplication::construct(); sysExcelWorkbooks = sysExcelApplication.workbooks(); try { sysExcelWorkbooks.open(excel, false /*Update links*/, true /*Read only*/); } catch (Exception::Error) { throw error(strFmt("@SYS76826", excel)); } sysExcelWorkbook = sysExcelWorkbooks.item(1); sysExcelWorksheets = sysExcelWorkbook.worksheets(); // Only considering Sheet 1 sysExcelWorksheet = sysExcelWorksheets.itemFromNum(1); sysExcelCells = sysExcelWorksheet.cells(); // Since in first row there will be field names. for ( rows = 2; rows
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 23:23.
