Старый 12.08.2012, 17:11   #1
axepclipboard: (ax2012) using jQuery in Enterprise Portal
Источник: http://feedproxy.google.com/~r/AxEpC...3/nJB0J9wjzGM/
I have already discussed how to use jQuery in 2009 Enterprise Portal. Here is how you can use it in 2012 Enterprise Portal. You had to put the jQuery library file in the SharePoint LAYOUTS folder in order to reference it. In 2012 it is made a lot easier since it is used for a [...]
axepclipboard: (Ax 2012) Enterprise portal development cookbook released Blog bot DAX Blogs 1 06.07.2012 11:11
AX2012 CU2, разработка Enterprise Portal в Visual Studio 2010 - как убить кэш? offenmeier DAX: Программирование 5 23.04.2012 06:35
axepclipboard: (Ax 2012) How to change the site URL of your Enterprise Portal Blog bot DAX Blogs 0 21.02.2012 01:14
axepclipboard: Enabling session state for your Enterprise portal site Blog bot DAX Blogs 0 30.03.2011 18:11
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
Часовой пояс GMT +3, время: 20:59.
