Старый 25.04.2012, 03:18   #1
emeadaxsupport: AX for Retail 2012: Store Connect missing mfc100u.dll error
Источник: http://blogs.msdn.com/b/axsupport/ar...dll-error.aspx
All components of AX for Retail 2012 now get installed via the unified AX installer.  One of the nice things about this installer is the built-in Prerequisites Validation checker that it has.
However, there is one missing prerequisite for the Store Connect installer;  you may get the following error when you launch the setup utility:
“The program can’t start because mfc100u.dll is missing from your computer.  Try reinstalling the program to fix this problem.”
The Retail Store Connect Settings utility requires the Visual Studio C++ runtime to be installed.  You can grab it here:
Once you have that installed you should be able to launch the utility and configure your Store Connect instance.
emeadaxsupport: 4. Solving Fill Utility errors on Microsoft Dynamics AX 2012 - Error executing code: Wrong argument types for comparison (another scenario) Blog bot DAX Blogs 2 08.02.2012 09:21
Часовой пояс GMT +3, время: 10:45.
