Старый 23.04.2012, 15:11   #1
palleagermark: How to change the UUID of a virtual disc for use with VirtualBox
Источник: http://palleagermark.blogspot.com/20...-disc-for.html
The virtual disc images we get from Microsoft usually have the same UUID as earlier disc images from Microsoft.
This is a problem if you wan't to run several images with VirtualBox because VirtualBox assumes, well that the different discs have different UUID's.
Here's how to change the UUID of new disc image.
Open a command prompt and go to the VirtualBox program folder. This is most likely C:\Program Files\Oracle\VirtualBox
Run the vboxmanage internalcommands sethduuid [file] command. For example:
vboxmanage internalcomands sethduuid "C:\DEMO\AX2012-A.VHD"
doens.be: How to run a Microsoft Ax 2012 Hyper-V on VirtualBox (Enterpris Portal Problem) Blog bot DAX Blogs 0 26.11.2011 12:11
Dynamics CRM Tools: How to: Change existing ribbon element properties Blog bot Dynamics CRM: Blogs 0 19.04.2011 12:11
emeadaxsupport: How to set the number sequence for Global Address Book when virtual companies are used Blog bot DAX Blogs 0 24.08.2009 14:05
palleagermark: Compacting your virtual harddisks Blog bot DAX Blogs 0 28.09.2008 17:13
Часовой пояс GMT +3, время: 21:09.
