Старый 09.03.2012, 14:11   #1
palleagermark: AX 2012 "Doh" upgrade experience
Источник: http://palleagermark.blogspot.com/20...xperience.html
When preparing to upgrade your code by import an old layer from the previous version, make sure that you don't import any changes to the SysCheckList classes.
If one of these won't compile on AX 2012 you're kind of stuck, unable to start AX properly until you uninstall the new model again.
Старый 10.03.2012, 23:18   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
М... в полку классов Application, Global, Info прибыло...
palleagermark: AX 2012 upgrade tip for lazy idiots like me Blog bot DAX Blogs 0 05.03.2012 18:11
palleagermark: "Find as you type" in the AX 2012 X++ editor Blog bot DAX Blogs 0 02.02.2012 15:11
palleagermark: Microsoft Dynamics AX 2012 White Papers: Code Upgrade Blog bot DAX Blogs 0 11.04.2011 19:11
Часовой пояс GMT +3, время: 14:58.
