Старый 29.02.2012, 20:34   #1
ideveloper is offline
ideveloper
Create XML-Export with AIF
Hi everybody.
We need to create a XML-Export from the invoice table which have a custom XSD-schema.
Could we achieve it using the AIF Objects which we create based on the query running the AIF-Wizard (without the webservices)
If yes, how can we do it?
(You can anser in russian too)
aif
emeadaxsupport: Cannot create Enterprise portal site with SharePoint 2010. Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml' Blog bot DAX Blogs 0 15.08.2011 23:11
emeadaxsupport: Error when trying to register the AIF services - "Cannot create a record in Data Policy Schema Information (AifDocumentField)" Blog bot DAX Blogs 0 29.03.2010 21:05
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 19.10.2008 18:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 25.03.2008 03:58
Часовой пояс GMT +3, время: 06:58.
