Старый 04.01.2012, 13:11   #1
ukax: New License Scoping Tool available
Источник: http://blogs.msdn.com/b/ukax/archive...available.aspx
Happy New Year all! Hopefully many of you have recovered from the excesses of Christmas, at points I’ve felt my brain still resembles the inside of a mince pie, however, this should sort it
A new License scoping tool, scoping guide and scoping recording is available on PartnerSource and the Partner Learning Centre. We (Royal we of myself and Andrew) will cover off the details at the next roadshows. However, for now, please ensure you have consumed the following:
On PartnerSource here you will find:
  • License Scoping Guide
  • Mapping Tool
Please scroll down the page until you hit the section “License Scoping for Business Value Licensing" where you will then see the links to the documents referenced above.
Recording on using the Guide and Mapping tool can be found here on the Partner Learning Centre.
As mentioned we will cover at the next roadshow so please make sure you get booked up once Andrew posts the details.
Posted By Fee Nolan
За это сообщение автора поблагодарили: gl00mie (3).
Channel9 CRM: CRM Translation Tool Blog bot Dynamics CRM: Blogs 1 17.09.2010 20:05
Sample Design Patterns: Complexity tool - Dynamics AX 2009 Blog bot DAX Blogs 0 30.07.2010 15:05
emeadaxsupport: Warning when loading license file - License value for ID 2024 has not been created (or License value for ID 2025 has not been created) Blog bot DAX Blogs 0 12.01.2010 04:44
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Online Data Import tool Blog bot Dynamics CRM: Blogs 0 05.06.2009 05:10
Часовой пояс GMT +3, время: 10:46.
