Старый 07.03.2008, 06:06   #1
gatesasbait: Improved AOT Queries in Ax2009
Источник: http://gatesasbait.spaces.live.com/B...B9F5!197.entry
Good afternoon,
One of the added features of Ax2009 is the improved AOT Query.
AOT Query objects can now be dragged and dropped onto a form's datasource, at which point datasources corresponding to the tables in the Query will be automatically added to the Form, with the proper joins and links. When doing this, a reference to that Form will be inserted under the AOT Query object, under a new node called 'Dependant Objects'. This way you can know where a particular Query is used. Queries now support 'Composite Queries', I haven't played with that much yet, but it seems to make possible combining Queries together by drag and drop.
Neat, but not revolutionary, it was already possible to use AOT Queries on forms back since Ax 2.5 at least, this makes it much more developer friendly though.
The latest build (459) is definitely more stable, but I wouldn't call it perfect still.
gatesasbait: AP Posting fails because of security setup in Dynamics Ax 4 Blog bot DAX Blogs 0 03.02.2009 02:07
gatesasbait: How to temporarily suppress infolog messages in Dynamics Ax (deux) Blog bot DAX Blogs 7 28.01.2009 17:45
gatesasbait: Reverse keyword on Select Statements Blog bot DAX Blogs 0 08.02.2008 00:10
gatesasbait: Ax5 product was renamed to Ax2009 Blog bot DAX Blogs 0 30.01.2008 20:30
gatesasbait: On data dictionary synchronization errors Blog bot DAX Blogs 0 29.11.2007 00:53
Часовой пояс GMT +3, время: 03:57.
