Старый 27.04.2011, 22:11   #1
dax-lessons: Create projects or sub projects using X++ [Dynamics AX]
Источник: http://dynamicsaxgyan.wordpress.com/...x-dynamics-ax/
Friends, below code will help you to create projects and sub projects using code. If there is already a parent project and we need to create sub projects based on the format which is already defined, the sample job below … Continue reading →
Часовой пояс GMT +3, время: 18:15.
