Старый 18.02.2011, 23:12   #1
sumitax: Reading XML Documentation
Источник: http://sumitax.wordpress.com/2011/02...documentation/
In my current project, I created a Automation testing solution using Unit Test Framework (UTF) .For retreving XML documentation from method (which contains what is purpose of method and what are parameters name and type ) .Following is code to access the string under XML documentation:
static void SUMIReadClassmethod(Args _args)
 SysDictClass dct;
 str Source ;
 Object objMethod;
 DictMethod dm;
 container conLines;
 TextBuffer textBuffer = new TextBuffer();
 Set dictClassMethodSet ;
 SetEnumerator enum;
 SysDictMethod dictMethod;
 #SysBpCheck
 FreeText ft
 dct = new SysDictClass(ClassName2id(classnode.AOTname()));
 dictClassMethodSet = dct.methods(true, true, true);
 dictClassMethodSet.add(new SysDictMethod(UtilElementType::ClassInstanceMethod,  (classnode.AOTname()), #MethodNameClassDeclaration));
 enum = dictClassMethodSet.getEnumerator();
 textbuffer = null;
 while (enum.moveNext())
 dictMethod = enum.current();
 textBuffer.appendText(dictMethod.xmlDocumentation());
dax-lessons: Generate XML Documentation Files for a project – DAX 2009 Blog bot DAX Blogs 0 14.12.2010 10:11
dax-ideas: Reading an XML file in AX 2009 Blog bot DAX Blogs 0 16.11.2010 22:11
workflowax: Documentation and Further Reading Blog bot DAX Blogs 0 02.07.2010 18:05
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 04.05.2009 14:05
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
Часовой пояс GMT +3, время: 01:02.
