Старый 22.12.2010, 08:11   #1
semanticax: How to unlock a Table in AX
Источник: http://semanticax.spaces.live.com/Bl...57F3!200.entry
Often we get this Error "Cannot able to modify a table since it has been locked by another user". we can see a lock symbol appearing on the table.
there is one way 2 unlock the tables by using the AOT itself ...
Go to AOT -> open systemdocumentation node ->
go to tables ->
select "UTILLOCKS" table
and then open the table browser and you can see the records having details of all the tables that are locked ,Select the table that you want to unlock then delete the record in the table.Restart AX and now you can see that the table has been unlocked.
Happy Daxing
Raghuram--------
Старый 22.12.2010, 10:40   #2
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
А главное, как просто-то можно даже оптимистическую модель не использовать, раз и все
Axapta book for developer
Старый 22.12.2010, 13:16   #3
Dron AKA andy is offline
Dron AKA andy
944 / 253 (10) ++++++
Можно и "по-человечески", через меню: Сервис / Средства разработки / Объекты приложения / Блокированные объекты приложения.
Андрей.
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
Pawan's Ax blog: How To Restore Data In AIFSchemaStore Table Blog bot DAX Blogs 0 01.07.2010 22:07
Everything AX: How to quickly get table row counts in Axapta Blog bot DAX Blogs 0 02.09.2009 16:05
Часовой пояс GMT +3, время: 21:47.
