Старый 02.12.2010, 14:57   #1
If you haven’t already read part 1 you should do so here, before continuing to read this post.
In part 1 I showed how a service reference plus two lines of code:
var client = new Proxy1.ProxyClassClient("NetTcpRelayBinding_IProxyClass");
Console.WriteLine(client.GetCustomerName("10000"));
could extract data from my locally installed NAV from anywhere in the world.
Let’s start by explaining what this does.
The first line instantiates a WCF client class with a parameter pointing to a config section, which is used to describe bindings etc. for the communication.
A closer look at the config file reveals 3 endpoints defined by the service:
<client>
   <endpoint
address="sb://navdemo.servicebus.windows.net/Proxy1/"
     binding="netTcpRelayBinding"
bindingConfiguration="NetTcpRelayBinding_IProxyClass"
     contract="Proxy1.IProxyClass"
     name="NetTcpRelayBinding_IProxyClass" />
   <endpoint
     address="
Часовой пояс GMT +3, время: 12:16.
