Старый 11.11.2010, 11:11   #1
sumitax: SharePoint 2010 and AX2009
Источник: http://sumitax.wordpress.com/2010/11...10-and-ax2009/
Following is link for compatibility patch for AX2009 Enterprise portal to run on SharePoint 2010.
http://blogs.technet.com/b/dynamicsa...gust-2010.aspx
But Sharepoint 2010 uses the same templates for EP as the old version SharePoint 2007 , so there should not be any major issues while implementing AX2009 with SharePoint 2010.
sumitax: Workflow Installation Steps -AX2009 Blog bot DAX Blogs 0 14.10.2010 23:06
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
sumitax: State management(ViewState) in Enterprise portal Blog bot DAX Blogs 0 29.08.2010 21:06
sumitax: Ax2009 Programming – Getting Started book Blog bot DAX Blogs 0 13.08.2010 21:06
Часовой пояс GMT +3, время: 14:29.
