Старый 17.08.2010, 22:06   #1
dynamicsaxtraining: Select statement patterns
Источник: http://www.dynamicsaxtraining.com/ti...ement-patterns
This article contains descriptions of select statement patterns that can be used in the Microsoft Dynamics AX (Axapta).
The list of select statement patterns provided is as follows:
  1. Enable/Disable condition
  2. Switch condition
  3. Enable/Disable join table with condition
Enable/Disable Condition
Use this pattern when the condition in the “where” clause is dependant of a parameter.
For example, we need to perform some procedure with either all Customer or Customers with invoice account only. It depends on the User input parameter. We create a periodic job with the following dialog box:
Process Customers
We will assume that the Customer with invoice account check box has the dialogField name in the code.
The select statement will have the following view in the “run” method:
while select custTable
where (!dialogField.value() || custTable.InvoiceAccount != '')
If the check box is selected, !dialogField.value() returns false and custTable.InvoiceAccount != ” will be taken into account. If the check box isn’t selected, !dialogField.value() returns true (so there is no sense what return the custTable.InvoiceAccount != ” condition). In other words, if the check box is selected, only Customers with Invoice accounts will be searched. Otherwise, all Customers will be searched.
General structure looks as follows: where (!EnableConditionFlag || condition)
Switch Condition
Use this pattern when either one or another condition dependant of parameter must be applied to the select statement.
For example, we need to perform a procedure with items of either a BOM item or items of other item types. We need to create a periodic job with a dialog box. The dialog box contains only one BOM type checkbox. We will assume that the BOM type check box has the dialogField name in the code.
In the run method, we write the following select statement:
while select inventTable
where ((!dialogField.value() && inventTable.ItemType != ItemType::BOM) ||
       (dialogField.value()  && inventTable.ItemType == ItemType::BOM))
If the BOM type check box is selected, the first parenthesis returns false and everything depends on the second parenthesis where the inventTable.ItemType == ItemType::BOM clause is checked. If the BOM type check box isn’t selected, the second parenthesis returns false and everything depends on the first parenthesis where the inventTable.ItemType != ItemType::BOM clause is checked. In other words, if the check box is selected, the only BOM item will be searched. Otherwise, only not BOM items will be searched.
General structure looks as follows: where ((!Condition2Flag && condition 1) || (Condition2Flag && condition 2))
Enable/Disable Join Table with Condition
Use this pattern when a joined table with a condition can either contain records or be empty.
For example, we need select sales orders without Recipient or terminated Recipient. The SalesTaker field in the SalesTable table stores the Recipient ID. The Status field in the EmplTable table stores the Recipient’s status (None, Employed, or Resigned).
The select statement has the following view:
while select SalesTable
notexists join EmplTable
where EmplTable.EmplId == SalesTable.SalesTaker &&
      EmplTable.status != HRMEmplStatus::Resigned
If EmplTable.status is Resigned or the Sales table record doesn’t have the Recipient, the Sales table record will be selected.
General structure looks as follows: notexists join where && (condition != required value)
If you know other interesting patterns, please write them in the comments
Technorati Tags: select statement, select statement patterns, where clause
Старый 18.08.2010, 01:05   #2
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
и главный pattern - не используйте эти patterns
используйте Query & QueryRun
За это сообщение автора поблагодарили: gl00mie (3).
Старый 18.08.2010, 12:16   #3
Volodymyr is offline
Volodymyr
Почему? Интересно что отработает быстрее Query или select?
Старый 18.08.2010, 12:32   #4
lev is offline
lev
Ищущий знания...
Аватар для lev
Oracle
1,723 / 491 (20) +++++++
Сообщение от Volodymyr Посмотреть сообщение
Одинаково должно отрабатывать по идее И то и другое отсылает сформированный запрос к базе.
Не один раз проводил тесты у себя, время выполнения всегда было идентично
Тут скорее вопрос в читаемости кода, и в удобности использования синтаксиса, и на мой взгляд, все зависит от ситуации
С Уважением,
Елизаров Артем
Старый 18.08.2010, 13:05   #5
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
If you need user interaction regarding the data you need processed, a query is the preferable way
Старый 18.08.2010, 13:27   #6
Volodymyr
Спасибо! Вобщем то если это переменная не из юзер интерфейса, то можно использовать. Я например очень часто первым Enable/Disable пользуюсь.
Старый 18.08.2010, 14:44   #7
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Подобные публикации так и побуждают понудеть...
В игрушечных базах оно, может, и без разницы, но в реальной жизни было замечено, что оптимизатор запросов СУБД совершенно по-разному реагирует на условия вида custTable.InvoiceAccount != '' и custTable.InvoiceAccount > '' - по смыслу они вроде как идентичны, но оптимизатору запросов так почему-то не кажется. К слову, и само ядро, если в запросе указать просто custTable.InvoiceAccount (неявно приводя InvoiceAccount к булевскому типу), формирует запрос с условием > '', а не != ''.
Вот это просто вошлебный пример! Фильтрация по неиндексированному полю SalesTable, да еще и с notexists join - вернейший способ получить полное сканирование таблицы с подзапросами к подчиненной таблице на каждую запись в SalesTable.
Скорее general structure looks as follows: не используйте notexists join на сколь-нибудь больших выборках - зачастую тупо перебрать записи, или закэшировать данные из подчиненной таблицы, или использовать какой-нить RecordSortedList для избавления от дублирующихся по определенным критерями записей оказывается с точки зрения производительности намного предпочтительнее. Вот уж действительно:
Сообщение от Wamr Посмотреть сообщение
За это сообщение автора поблагодарили: Wamr (3), Logger (5), oip (1), Volodymyr (1).
Старый 19.08.2010, 12:57   #8
Volodymyr
Привет. Кажется не туда копать стали.
Как по мне интерес представляет именно "шаблон", а не условие.
Структура первая, вида :
while
select custTable
Позволяет включать выключать любое условие, а какое оно дело рук каждого.
Удобно и практично, ну можно и кверей никто не спорить.
Насчет notexists join опять же дело рук каждого.
Соглашусь что примере приведены не самые лучшие.
Но идея хорошая.
Старый 19.08.2010, 19:12   #9
gl00mie is offline
gl00mie
Мне лично Query больше нравится тем, что:
  • можно разбить логику построения запроса на несколько методов, а их - выборочно перекрывать в различных классах-наследниках; для while select нужно либо переписывать запрос целиком, либо в базовом классе предусматривать все возможные условия в запросе и цеплять их тем способом, который был представлен (!flag || condition), что не прибавляет коду наглядности и понятности;
  • после добавления всех нужных условий по Query легко увидеть без включения трассировки, какой же в результате запрос получился;
  • Query можно передать в другой кусок кода, который не знает, как он был сформирован, а только знает, записи из какой таблицы нужно выбирать;
  • Query можно легко переделать для рассчета каких-нить агрегатов вместо перебора записей (бывает, люди хотят видеть на форме поле с суммой по всем записям, удовлетворяющим текущему запросу, - с Query это сделать проще простого);
  • в Query не надо извращаться, если какой-то datasource нужно цеплять только по определенному условию, потому что этому datasource'у можно сказать enabled(false) - и он уже не попадет в запрос;
  • при использовании Query по умолчанию включена RLS - в случае чего, не надо потом бегать и в куче мест дописывать перед запросом salesTable.recordLevelSecurity( true ).
Старый 20.08.2010, 00:37   #10
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Я вам не скажу за всю Одессу, но на MSSQL not exists join давно уже вроде как разрешается через right anti semi join с разовым table\index scan-ом, не так уж все и страшно, как может показаться
Да, любое условие, прописанное разработчиком. А так как требования к продукту у нас обычно определяются уже на этапе тестирования, получаем в итоге бедного разработчика, осаждаемого парой-тройкой Петровичей с их безумными взаимоисключающими хотелками, монстроидальные формы и мостроидальные запросы. То ли дело Query - один раз пользоваться научил, сиди, твори спокойно
-ТСЯ или -ТЬСЯ ?
Старый 20.08.2010, 14:01   #11
Wamr is offline
Wamr
Записей в блоге: 7
вот к чему в конечном итоге приводит любовь к "хорошей идеи"
    while select
    sum(Qty), sum(costAmountPosted), sum(costAmountAdjustment) from InventTrans
    group by ItemId
    where
    (!itemId || InventTrans.ItemId == itemId)
            !dateFrom
                InventTrans.DatePhysical > dateFrom
                    isTime
                        InventTrans.DatePhysical == dateFrom &&
                            InventTrans.GM_DatePhysical > dateFrom
                                InventTrans.GM_DatePhysical == dateFrom &&
                                InventTrans.AX_TimePhysical >= timeFrom
            !dateTo
                InventTrans.DatePhysical < dateTo
                    isTime
                        InventTrans.DatePhysical == dateTo &&
                            InventTrans.GM_DatePhysical < dateTo
                                InventTrans.GM_DatePhysical == dateTo &&
                                InventTrans.AX_TimePhysical < timeTo
        InventTrans.StatusReceipt == StatusReceipt::Purchased ||
        InventTrans.StatusReceipt == StatusReceipt::Received ||
        InventTrans.StatusIssue == StatusIssue::Sold ||
        InventTrans.StatusIssue == StatusIssue::Deducted
    && InventTrans.TransType == InventTransType::Sales
    join salesTable group by GM_SalesOperationType where
    salesTable.SalesId == inventTrans.TransRefId
    join inventDim group by inventDimDefect where
    inventDim.inventDimId == inventTrans.inventDimId &&
    (!defect || inventDim.inventDimDefect == defect)
    exists join GM_CalcInventLocationOperational where
    dataAreaAdmin ||
    (!dataAreaAdmin && GM_CalcInventLocationOperational.InventLocationId == inventDim.InventLocationId)
    exists join GM_CalcInventLocationAdministrative where
            dataAreaAdmin &&
            GM_CalcInventLocationAdministrative.CalcInventLocation == GM_CalcInventLocation &&
            GM_CalcInventLocationAdministrative.InventLocationId == inventDim.InventLocationId
            !dataAreaAdmin &&
            GM_CalcInventLocationAdministrative.InventLocationId == GM_CalcInventLocationOperational.AdministrativeInventLocationId &&
За это сообщение автора поблагодарили: fed (5), Lemming (5), gl00mie (2).
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Rajdip's space: When using index (not using hint) in a select statement without 'GroupBy' or 'OrderBy' in what sequence do the records occur Blog bot DAX Blogs 0 20.04.2010 20:05
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
dynamicsaxtraining: Setup initial data (Vendor, Warehouse, Equipment) Blog bot DAX Blogs 0 07.12.2009 19:05
Fred Shen: Always use recId to know if a select statement returns a record Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 15:45.
