Старый 04.09.2009, 01:06   #1
Dianne Siebold: Message Encoding in AIF
Источник: http://blogs.msdn.com/dsiebold/archi...ng-in-aif.aspx
Recently, I was on a mail thread that elucidated certain aspects of how AIF messages are encoded. So I thought I would share that info here.
In Microsoft Dynamics AX 2009, the default encoding is UTF-8. You can change the default in the global settings form by navigating to Basic > Setup > Application Integration Framework > Global settings.
The important thing to remember is that each endpoint has its own default encoding format, and that encoding is inherited from the encoding format specified in the global settings. So if you want to change the encoding on a single endpoint, you need to go to the endpoints form by navigating to Basic > Setup > Application Integration Framework > Endpoints > General tab.
If you change the default encoding format on the global settings form, it does not change the default encoding format on any existing endpoints. Only endpoints created after the change to the global settings will inherit the new global default encoding format.
Another important point to remember: Outbound documents (messages) that are being sent in response to an inbound request always use the encoding of the inbound request document.
The encoding formats supported by AX are:
· UTF-8
· UTF-16
· UTF-16BE
· GB18030
For more information than you’d ever want to know about Unicode encoding formats, check out the Unicode Consortium.
Dianne Siebold: Getting Error Details in AIF Blog bot DAX Blogs 0 01.04.2009 05:07
Dianne Siebold: AIF Services & Locale Blog bot DAX Blogs 0 09.12.2008 11:05
Dianne Siebold: Video About the AIF Services and WCF Blog bot DAX Blogs 0 11.10.2008 07:43
Dianne Siebold: Guide to AIF Documentation Available Blog bot DAX Blogs 0 25.06.2008 06:14
Dianne Siebold: AIF Top Ten Blog bot DAX Blogs 1 22.04.2008 11:19
Часовой пояс GMT +3, время: 09:59.
