Старый 03.07.2009, 22:05   #1
Arijit Basu: AX EP Role Centre inside Outlook [Short n Sweet :)]
Источник: http://daxguy.blogspot.com/2009/07/a...ook-short.html
I was just playing around with Outlook and AX trying to see see if the Role centre could be got into outlook as a default homepage. Well the simple way is to add the EP link as the defailt homepage , but it didnt look to good , with the menu etc. However if you append '&RUNONCLIENT=1' at the end on the EP RC URL, the menu's get chopped off and you see the Role centre real cool. Say if the URL is 'http://arijit:150/sites/DynamicsAx/Enterprise%20Portal/RoleCenterCEO.aspx?WCMP=CEU' then append '&RUNONCLIENT=1' at the end of the url [http://arijit:150/sites/DynamicsAx/Enterprise%20Portal/RoleCenterCEO.aspx?WCMP=CEU&RUNONCLIENT=1] and the heads of the MOSS/WSS site get chopped off. Pretty kool. See the screenshot below from my Outlook default homepage with AX CEO RC :)
Happy DAXing :-)
enterprise portal, outlook, корпоративный портал, полезное
Arijit Basu: AX Intelligent Data Management Tool : Inside look Blog bot DAX Blogs 0 02.07.2009 22:05
Arijit Basu: AX 2009 Document Management & MOSS / WSS Blog bot DAX Blogs 0 23.01.2009 01:07
Arijit Basu: Reporting & BI in AX: An Overview [Level 100] Blog bot DAX Blogs 0 07.01.2008 16:01
Arijit Basu: Microsoft Dynamics AX 4.0 SP1 Role based Business Intelligence Blog bot DAX Blogs 0 20.07.2007 11:50
Часовой пояс GMT +3, время: 03:30.
