Старый 30.06.2009, 17:05   #1
axaptapedia: Match
Источник: http://www.axaptapedia.com/Match
Summary: New page: Here is a method for searching (matching) text in the classical style: If for instance the InventTable must be searched for records whos item name contains the text MUSTER, this method ca...
contains the text MUSTER, this method can be called with the parameters:
if (myMatch('*MUSTER*', inventTable.Itemname))
    // Then do something
The method return true if a match was found and false otherwise.
static boolean myMatch(str _matchKey, str _text)
    str     matchKey        = _matchKey;
    str     text            = _text;
    str     tokKey;                             // Match Key Token  -  Holds actual Character being examined
    str     tokText;                            // Text Token       -  Holds actual Character being examined
    str     laTok;                              // Look Ahead Token -  Holds Character one Positition after Token Character
    int     lenKey;                             // Key Length
    int     lenText;                            // Text Length
    int     incKey;                             // Incrementor for Key
    int     incText;                            // Incrementor For Text
    int     laKey;                              // Look Ahead Incrementor for Key
    boolean ret             = true;
    #define.WC_MANY ('*')
    #define.WC_ONE  ('?')
    if (!matchKey)
        matchKey = #WC_MANY;
    lenKey  = strlen(matchKey);
    lenText = strlen(text);
    incText = 1;
    for (incKey = 1; incKey  lenText)
            ret = false;
        switch (tokKey)
            case #WC_MANY   :
                if (incKey < lenKey)
                    laKey   = incKey + 1;
                    laTok   = substr(matchKey, laKey, 1);
                    if (strscan(text, laTok, incText, strlen(text)))
                        incText = strscan(text, laTok, incText, strlen(text));
                        if (!myMatch(
                                     substr(matchKey, incKey + 1, strlen(matchKey)),
                                     substr(text, incText, strlen(text))
                            incKey--;
                            incText++;
                        else
                            return true;
                    else
                        return false;
                else
                    return true;
                break;
            case #WC_ONE    :
                incText++;
                break;
            default         :
                if (tokKey == substr(text, incText, 1))
                    incText++;
                else
                    return false;
                break;
    if (incText < lenText)
        ret = false;
    return ret;
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axaptapedia: Regular expressions Blog bot DAX Blogs 0 04.06.2008 02:06
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 19:05.
