#1 |
Solutions Monkey: Getting Around Thread was being aborted error when creating EP site.
Источник: http://blogs.msdn.com/solutions/arch...g-ep-site.aspx
============== Wishing you all a Very Happy New Year!!! When you are trying to create EP Site on a machine low in memory or processing power, some times you may get “Thread was being aborted.” Error. To avoid this error, you should increase the executiontimeout. Change connection time-out properties in the web.config file 1. In a basic text editor such as Notepad, open the web.config file for example %SYSTEMDRIVE%\Inetpub\wwwroot -or- %SYSTEMDRIVE%\\Inetpub\wwwroot\wss\VirtualDirectories\80 folder 1. Press CTRL + F to open the Find dialog box. 2. Find the following tag: 3. Replace it with this tag: 4. Find the following tag (you might have to search from the beginning of the file): 5. Add the following tags on new lines after the tag: 6. Find the following tag: 7. Add the following tags on new lines after the tag: 8. Save your changes, and close the web.config file. 9. At the command prompt, type iisreset, and then press ENTER. 10. Try to create the top-level Web site in SharePoint Portal Administration. ============== Источник: http://blogs.msdn.com/solutions/arch...g-ep-site.aspx
