Старый 14.06.2008, 14:10   #1
Arijit Basu: Using AX .NET BC to create Purchase Orders
Источник: http://daxguy.blogspot.com/2008/06/u...-purchase.html
A small but nice project to create multiline Purchase Orders in AX from a .NET Windows application. In this small POC, there is a Windows Application (C#) which uses the .NET BC to create PO into AX. Its a simple demo but can be extended to other areas like journals, Sales Orders , Inventory Transactions (any multiline header - detail type). For this a small class is written inside AX which exposes the logic. I have used the AXPurchTable() & AXPurchLine() classes to enter PO in AX. There is a similar post in MSDN (Using Axapta Business Connector to Create Microsoft Business Solutions–Axapta Sales Orders) but that uses the COM Connector & consists only of a single line. This sample can support multiline PO :). I have not worked too much on the validations & other advanced areas. The C# code also may not be the best :) but its simple.
The video on how to use it is attached below [Assumes that the current logged in user has User rights to AX]
AX Purchase Order using .NET BC
I have also uploaded all source files in the link below.
Let me know if anyone has a better way of doing this.
Happy DAXING :)
Arijit Basu: AX 2009 Document Management & MOSS / WSS Blog bot DAX Blogs 0 23.01.2009 01:07
Arijit Basu: DAX 4.01 .NET Business Connector: Microsoft.Dynamics.BusinessConnectorNet Blog bot DAX Blogs 3 30.09.2008 01:17
Arijit Basu: AX .NET BC - Sample Project [Level 100] Blog bot DAX Blogs 0 28.04.2008 13:05
Arijit Basu: Reporting & BI in AX: An Overview [Level 100] Blog bot DAX Blogs 0 07.01.2008 16:01
Часовой пояс GMT +3, время: 12:40.
