Старый 15.05.2008, 22:05   #1
Malaysia: Spell checking from AX
Источник: http://axmas.blogspot.com/2008/05/sp...g-from-ax.html
The AX class SysSpellChecker is a wrapper for the spellchecker of Word. Using this class you can offer spellchecking from AX.
Here is some sample code, checking text from a form string control:
SysSpellChecker spellChecker = SysSpellChecker::newCurrentLanguage();
TextBuffer textBuffer = new TextBuffer();
int wordStart;
int startSeparator;
int endSeparator;
str wordToCheck;
List spellingSuggestions;
ListEnumerator listEnumerator;
super();
startLengthyOperation();
setPrefix("Spell check");
textBuffer.setText(stringEdit.text());
startSeparator = 1;
while (startSeparator)
    wordStart = textBuffer.find('[^ \n\t\\!\\'\\\#\%\&\/\(\)\=\?\,\.\:\;\*\}\{\]', startSeparator) ? textBuffer.matchPos():0;
    if (!wordStart)
        break;
    endSeparator = textBuffer.find('[ \n\t\\!\\'\\\#\¤\%\&\/\(\)\=\?\,\.\:\;\*\}\{\]', wordStart)? textBuffer.matchPos():0;
    wordToCheck = textBuffer.subStr(wordStart, (endseparator ? endseparator : textBuffer.size()+1) - wordStart);
    if (spellChecker.checkSpelling(wordToCheck) == false)
        warning (strfmt("@SYS84009", wordToCheck));
        spellingSuggestions = spellChecker.getSpellingSuggestions(wordToCheck);
        listEnumerator = spellingSuggestions.getEnumerator();
        while (listEnumerator.moveNext())
            info (strFmt("Suggestion: %1", listEnumerator.current()));
    startSeparator = endSeparator;
spellChecker.finalize();
info ("Spell check done");
endLengthyOperation();
Unfortunately there is a bug in the checkSpelling method of the COM object from Word, so it will always use the default language of your Office setup as the language to check your text against. So you can't spellcheck for other languages than your default language of Office. You can change the default language from the Office Tools however.
*from http://palleagermark.blogspot.com/
msdynamicsax: Upgrading a database from Ax 4.0 SP1 to Ax 2009 Blog bot DAX Blogs 1 13.08.2008 14:02
Khue Trinh: AX 2009 Quality Management - Quality Control Blog bot DAX Blogs 1 04.07.2008 16:01
palleagermark: Spell checking from AX Blog bot DAX Blogs 0 04.04.2008 10:05
Часовой пояс GMT +3, время: 22:08.
