Старый 04.05.2008, 23:05   #1
Arijit Basu: Infopath, Web Services & AX Integration
Источник: http://daxguy.blogspot.com/2008/05/i...tegration.html
A small quick demo on how to interface Infopath forms with AX using Web Services. In this small simple demo I have created a new supplier registration infopath form which can be posted to the company website. Any supplier
interested in registering can fill up the form and submit it to AX via Web Services. To do this, the following things were required:
1. A class in AX which holds the AX business logic to create new records in VendTable [Class_AXWS.xpo]
2. A Web Service (ASP.net) which invokes this AX class via .net Business Connector
3. A Infopath form which uses this web service [AXVendor.xsn]
First create/ import the class in AX. Then create a Web Service which invokes this class using .net Business Connector. Then create a Infopath form to use this Web Service to interface with AX.
The Web Service which interacts with AX:
The Web Service Code:
The Infopath Form:
Video of the completed application:
Infopath, Web Services & Dynamics AX
Source Code: [Contains all source files & raw video :)]
Happy DAXing:)
Arijit Basu: AX 2009 Document Management & MOSS / WSS Blog bot DAX Blogs 0 23.01.2009 01:07
Dynamics AX: DAXGuy: Infopath, Web Services & AX Integration Blog bot DAX Blogs 0 08.05.2008 03:18
Arijit Basu: Reporting & BI in AX: An Overview [Level 100] Blog bot DAX Blogs 0 07.01.2008 16:01
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Часовой пояс GMT +3, время: 03:57.
