Старый 31.10.2007, 05:34   #1
gl00mie: Run DAX4 AOS as a console application
Источник: http://gl00mie.blogspot.com/2007/10/...plication.html
I've recently found an interesting feature of DAX4 Object Server: it can run not only as a service, but also as a console application started from command line. All you have to do is pass a console parameter before the configuration number, e.g.
ax32serv.exe /console 01
This feature was probably added for debugging purpose as it's rather difficult to start a Windows service under a debugger.
When started as a console application AOS can be terminated by pressing Ctrl-C or Ctrl-Break.
Запуск AOS DAX4 в качестве консольного приложения gl00mie DAX: Администрирование 12 05.11.2021 22:10
Application Error и падение AOS Vladyslav DAX: Администрирование 4 17.09.2021 17:08
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Часовой пояс GMT +3, время: 04:01.
