Старый 10.04.2007, 21:12   #1
casperkamal: Creating graphs in Dynamics Ax
Источник: http://casperkamal.spaces.live.com/B...CD63!262.entry
Creating a Graph with Dynamics Ax is quite easy. This article will deal on creating a simple graph.
The Graphics class in Ax helps out in creating graphs.
To Start with on using this class we shall creat a simple form ,
     1. Add a activex control of type ChartObject to the  Form
     2. You can either directly use the graphics class to display the data
         when there is no user interaction.
     3. Now creat a method called createGraph in your form
         > In this method let us attempt to show all the Total accounts against their balance provided their
            balance value is greater than zero. The code would be something like this
           LedgerTable ledgerTable;
           #chartFx
           //GraphicsWindow - Activex control name
           graphics = Graphics::newGraphicsTitlesLayout(GraphicsWindow, 100, 200,
                                            'Title', 'X', 'Y', 'z',#CT_TOOL ,1,  1, 1);
          graphics.create();
          graphics.parmTitleXAxis('AccountNum');
          graphics.parmTitleYAxis('Balance');
          graphics.parmHeight(150);
          graphics.parmWidth(300);
          while select AccountNum from ledgerTable where ledgerTable.AccountPlType == LedgerAccountType::sum
             if (ledgerTable.balance() > 0)
                graphics.loadData(ledgerTable.AccountNum, '', ledgerTable.balance());
          graphics.showGraph();
       4. Call this method on the init method of your form
       5. Now Just compile save and run, you should get a graph like the one below ..... so simple right :)
         on the next post let us see about extending and using the graphics class
................  mmm how about making salary graphs !!!!!
Старый 10.04.2007, 21:39   #2
на русском http://axapta.mazzy.ru/lib/graphics/
chart, график
casperkamal: Creating new Syscontext Menu in Dynamics Ax 4.0 Blog bot DAX Blogs 0 06.06.2007 10:07
casperkamal: creating Transparent forms in Dynamics Ax Blog bot DAX Blogs 0 20.04.2007 19:20
Часовой пояс GMT +3, время: 01:03.
