Старый 06.08.2005, 04:02   #1
gb is offline
gb
ODBCConnection Execute Select
Hello,
I am trying to execute Select using ODBCConnection. I constructed sql string and then tried to execute it.
sqlstr = "SELECT [Order].order_status_id, Claim.claimstatus_id FROM [Order] INNER JOIN Claim ON [Order].claim_id=Claim.claim_id AND [Order].order_id=999999";
I get this error message. Does anybody know why?
Message (18:53:36)
1952621871 999999 19526218
Cannot read a record in ().
The SQL database has issued an error.
[Microsoft][ODBC SQL Server Driver][SQL Server]Changed language setting to us_english.
If I execute just this:
sqlstr = "SELECT [Order].order_status_id, Claim.claimstatus_id FROM [Order] INNER JOIN Claim ON [Order].claim_id=Claim.claim_id";
I don't get the error.
Thanks in advance.
Старый 06.08.2005, 12:22   #2
Ned is offline
Ned
Lean Six Sigma
680 / 99 (5) ++++
What type is [Order].order_id field?
Viacheslav Nefedov, http://www.nefedov.net, http://restock.guru/
Старый 06.08.2005, 13:33   #3
when using filters, use the where clause instead
so:
join Claim on Claim.field=Order.field WHERE Order.field=99999
Hope this helps
Старый 06.08.2005, 17:27   #4
gb is offline
gb
Order_ID is integer.
Старый 06.08.2005, 17:27   #5
gb is offline
gb
It didn't help. I get the same error.
Старый 06.08.2005, 18:03   #6
gb is offline
gb
I got it working.
thank you everyone
Старый 07.08.2005, 00:00   #7
Well, share the solution with us, will you?
Thanks
2 while select или join? _scorp_ DAX: Программирование 9 23.01.2009 16:02
Разница NotInTTS и Found Logger DAX: База знаний и проекты 6 18.09.2008 12:35
gatesasbait: Reverse keyword on Select Statements Blog bot DAX Blogs 0 08.02.2008 00:10
Fred Shen: Always use recId to know if a select statement returns a record Blog bot DAX Blogs 0 28.10.2006 16:40
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 11:38.
