Старый 03.09.2023, 04:10   #1
Ledger dimension vs Default dimension
Источник: http://alexvoy.blogspot.com/2023/09/...dimension.html
In short Ledger dimension it is Main account + default dimension.
So, if you need to replace any attribute value in a given Ledger dimension, do not forget to get a Default dimension first.
LedgerDimensionFacade::getDefaultDimensionFromLedgerDimension(ledgerjournalTrans.LedgerDimension);
Then you can use this old good way.
DimensionDefault newDim = DimensionHelper::setValueToDefaultDimension(hcmEmployment.DefaultDimension, DimensionAttribute::findByName(_dimensionName).RecId, _dimensionValue);
BTW, the opposite thing works like that:
LedgerDimensionFacade::serviceCreateLedgerDimension(mainAccountRecId, inventTrans.defaultDimension);
Supporting method
public static DimensionDefault setValueToDefaultDimension(DimensionDefault _dimensionDefault, RefRecId _dimensionAttributeRecId, DimensionValue _newDimensionValue) { DimensionAttributeValueSetStorage dimStorage; DimensionDefault newDimensionDefault = _dimensionDefault; DimensionAttributeValue dimensionAttributeValue; if (_dimensionAttributeRecId) { dimStorage = DimensionAttributeValueSetStorage::find(_dimensionDefault); if (_newDimensionValue) { dimensionAttributeValue = DimensionAttributeValue::findByDimensionAttributeAndValue(DimensionAttribute::find(_dimensionAttributeRecId), _newDimensionValue, false, true); dimStorage.addItem(dimensionAttributeValue); } else { dimStorage.removeDimensionAttribute(_dimensionAttributeRecId); } newDimensionDefault = dimStorage.save(); } return newDimensionDefault; }
https://alexvoy.blogspot.com/2015/10...value-for.html
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
ax_gfm_framework_team: Dimension defaulting - Part 5 (Ledger dimension creation) Blog bot DAX Blogs 0 13.09.2014 01:12
sumitsaxfactor: Replacing Financial Dimension in Ledger Dimension Blog bot DAX Blogs 0 19.01.2012 13:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 03:45.
