Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 12.03.2008, 13:08   #1
newbie is offline
newbie
Lookup Question
HI all,
I just started AX 4.0. I am modifyin CustTable Form. I added a field to CustTable to hold emplid. So in form I have a lookup automatically created for selecting empIid.Its ok uptill here, Now my question is.
I also need to display a field next to that lookup field, which is not editable. When user selects Id from lookup, emp name should be populated in that non editable textbox.How should i do that.
2nd question.
In tab page Contact Information. lookup is in 2nd column, underneath a group.I want to display that non edit textbox next to the Lookup field, if i make columns 3 , textbox goest to the top but i want it next to lookup. Do i have to set left and top properties to control it.
Any help will be much appreciated.
Thanks
Старый 13.03.2008, 12:24   #2
1. Create a display method that returns the Employee Name based on the Id (field from the table that you created)
2. You rarely need to set fixed Left/Top position for controls in AX.
You can do all of it by using groups and specifying the number of columns in these groups.
there are plenty of examples in AX iteself - find one that resembles your scenario and investigate
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
Нагло глючит lookup Sada DAX: Программирование 1 08.06.2006 10:32
Динамические Lookup формы. Андрей Василюк DAX: База знаний и проекты 0 07.12.2001 07:07
Произвольная Lookup форма Maxim Gorbunov DAX: База знаний и проекты 0 30.11.2001 21:59
Часовой пояс GMT +3, время: 00:22.
