Старый 06.09.2023, 08:11   #1
25,475 / 846 (79) +++++++
shashidotnet: Make your VM run faster
Источник: https://shashidotnet.wordpress.com/2...vm-run-faster/
Each time you build your code, iisexpress will reset AND then the wait begins for the page to load.
Now some machines may be better than others, but windows defender seems to interfere and scan files which can cause considerable delays.
So lets make this run faster!
Windows Defender runs in the background and any files being used can be scanned by it. Those files will only be released after the scanning is complete. You can see in Task Manager that the process for MsMpEng.exe is busy.
You can look at the files being scanned using the Powershell commands
  1. Open a Powershell terminal in Administrator mode
  2. Run the commands listed here: https://github.com/shashisadasivan/M...ll/envPrep.ps1
  3. Done, MsMpEng.exe will be slightly less intrusive
shashidotnet: D365 FO EDMX / OData trimmer – Make your metadata smaller Blog bot DAX Blogs 0 06.05.2019 00:13
shashidotnet: SystemSequences Update Blog bot DAX Blogs 0 14.09.2017 13:11
Dynamics NAV Faster & Better: Let’s make G/L correspondence creation faster in Russian localized NAV 2017 Blog bot NAV: Blogs 0 20.06.2017 18:11
Часовой пояс GMT +3, время: 06:33.
