Старый 08.12.2011, 16:11   #1
25,475 / 846 (79) +++++++
daxdilip: Tip str2CapitalWord function to convert string into TitleCase
Источник: http://feedproxy.google.com/~r/blogs...o-convert.html
We have some custom export routines written in our solution which ftp's .csv file from AX. Now, the target system needed one of the column names in TitleCase.
Solution:
In my previous experience, I have used strUpr and strLwr functions in AX, but never had a requirement to convert something into TitleCase, Initially, for a quick workaround, I used Proper function in Excel to convert the column into TitleCase. But, the right way to fix was in the source program. so as soon as I got some time did bit of digging in AX standard functions and found out we have 2 functions:
1. str2Capital
This function just converts the first letter of the word as UpperCase so didn't match my requirements e.g.
Input String : "new south wales"
Output String: print str2Capital("new south wales") returns New south wales
2. str2CapitalWord
This function was exactly what I was looking for. It converts the first letter of each word in the sentence to
uppercase.
Input String: "new south wales"
Output String: "New South Wales"
Последний раз редактировалось Poleax; 08.12.2011 в 23:37.
Старый 20.11.2023, 10:33   #2
Damn is offline
Damn
436 / 154 (6) ++++++
С помощью какой функции можно обработать следующую ситуацию ?
Input String : "new south Wales"
Output String: "New south Wales"
Конечно что здесь можно использовать сочетание strPoke, strUpr и subStr. Но вдруг есть штатная функция.
Дмитрий
daxdilip: Tip – EP Customization ( Dynamically Loading Report Folder from Network based on Store Parameter) Blog bot DAX Blogs 0 08.06.2011 02:11
daxdilip: Tip How to Trace a Call to an AIF Web Service Blog bot DAX Blogs 0 26.11.2010 00:12
daxdilip: Tip: How to display the AOS Name at the status bar Blog bot DAX Blogs 5 15.11.2010 13:55
CRM DE LA CREME! Some useful CRMform jscripts Blog bot Dynamics CRM: Blogs 0 02.09.2009 10:05
Часовой пояс GMT +3, время: 06:57.
