Вернуться   AXForum > Рынок > Microsoft и системы Microsoft Dynamics
Старый 20.04.2011, 13:20   #1
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2155 (80) +++++++++
Microsoft Dynamics AX 2009 SP1 Rollup7 (RU7)
В планах МС седьмой роллап планируется в апреле (http://download.microsoft.com/docume...09/AX_plan.pdf)
А на PartnerSource уже доступны документы с изменениями в ru7, ссылка на изменения для РФ: https://mbs.microsoft.com/partnersou...ext=rollup%207.
Ivanhoe as is..
За это сообщение автора поблагодарили: pm-erp (1).
Старый 20.04.2011, 13:54   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Тоже самое, но чтоб не забирать через partnersource, документ в свободном доступе Microsoft Dynamics AX 2009 SP1 White Paper: Country-Specific Update for the Russian Federation for Hotfix Rollup 7
Brief Description
This white paper describes Microsoft Dynamics AX features that were released in hotfix rollup 7, and that are specific to users in the Russian Federation.
На сайте https://sharepoint.partners.extranet.../AllItems.aspx пока русской доки Rollup 7 нет.
P.S. наверно надо подождать пару дней.
Partnersource https://mbs.microsoft.com/partnersou...rintpage=false
Customersource https://mbs.microsoft.com/customerso...rintpage=false
This white paper describes country-specific updates that were released for the Russian Federation in hotfix rollup 7 for Microsoft Dynamics AX 2009 SP1.
In accordance with Russian legislation, the Manually write-off method has been updated. You can specify the calculation type for a write-off method as amount or percent, and you can specify the write-off amount for each interval or the percentage of the total to be written off in each period.
When you create a deferral manually, the deferral is created with a status of Scheduled, and you can use the Receipt transaction type to create transactions in a deferral journal for such deferrals. When you generate deferrals by using the periodic process, or when you dispose of a fixed asset and you incur a loss, deferrals are created with a transaction type of Receipt. You can also reverse the receipt transaction for both manually created deferrals and the deferrals that are generated by using the periodic process.
In accordance with Russian legislation, companies that pay value added tax (VAT) must complete the VAT declaration report and submit it to the sales tax authorities no later than the twentieth day of the month following the close of the tax period. Section 3 of the VAT declaration report is updated based on the facture data and the restored VAT data from sales and purchase books. The data includes any prepayments that are received from customers and prepayments that are paid to vendors. Application 1 in Section 3 in the VAT declaration report is updated with fixed asset data.
For more information about the hotfix download, see Microsoft Knowledge Base article 2503850. For more information about other features that apply to the Russian Federation, refer to the Applications and Business Processes Help. Information that is specific to the Russian Federation includes (RUS) in the title.
Click the link to open the download page, where you can view or download the document in PDF or XPS format.
Последний раз редактировалось Poleax; 21.04.2011 в 17:11. Причина: customersource
Старый 20.04.2011, 21:25   #3
Andpil is offline
Andpil
Что интересно я вчера успел скачать Rollup 7 по ссылке
http://hotfixv4.microsoft.com/Micros...l_i386_zip.exe
А сегодня ссылка уже невалидная, наверное MS опять накосячил со сборкой роллапа и по-быстрому ссылку прикрыли. Кому интересно могу выложить то что скачалось вчера.
Старый 25.04.2011, 09:15   #4
d&m is offline
d&m
MCT
Аватар для d&m
Manzana Group
459 / 186 (7) ++++++
Записей в блоге: 6
ru7 доступен для загрузки:
https://mbs2.microsoft.com/Knowledge...&wa=wsignin1.0
ссылка на закрытый ресурс
Sometimes there is a moment as you are awakening - when you become aware of the real world around you, - but you are still dreaming. - You may think you can fly but you do better not try.
За это сообщение автора поблагодарили: EVGL (3), sukhanchik (2).
Старый 25.04.2011, 10:32   #5
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Ссылка на скачивание (доступная всем): http://support.microsoft.com/hotfix/...503850&kbln=ru
Ivanhoe as is..
За это сообщение автора поблагодарили: Daiver (1).
Старый 25.04.2011, 11:11   #6
Poleax is offline
Poleax
Аватар для Poleax
Записей в блоге: 34
Для Microsoft Dynamics AX 2009 SP1 Rollup 7 KB2503850
Для Microsoft Dynamics AX 2009 Rollup 7 теперь не будет? Я правильно понял?
Старый 25.04.2011, 20:50   #7
Jabberwocky is offline
Jabberwocky
Microsoft Dynamics
Аватар для Jabberwocky
274 / 307 (11) ++++++
Да, для AX 2009 RTM не будет.
You should use Bing before asking dumb questions.
За это сообщение автора поблагодарили: Poleax (1).
Старый 26.04.2011, 20:11   #8
25,497 / 847 (79) +++++++
Dynamics AX Sustained Engineering: Dynamics AX 2009 Rollup 7 has been released to PartnerSource and CustomerSource
Источник: http://blogs.technet.com/b/dynamicsa...mersource.aspx
We're happy to announce to release of Dynamics AX 2009 Rollup 7 for AX 2009 SP1 customers. The release is available on PartnerSource and CustomerSource.
Due to the cumulative nature of the rollups, RU-7 carries all the content that has been released in previous rollups (RU-1, RU-2, RU-3, RU-4, RU-5, RU-6).
For more information, please refer to the following knowledge base article:
Старый 27.04.2011, 12:52   #9
d&m is offline
d&m
MCT
Аватар для d&m
Manzana Group
Записей в блоге: 6
ждем документацию на русском...
Старый 08.09.2011, 11:57   #10
mnt_dx is offline
mnt_dx
Axapta Retail User
1,746 / 188 (10) ++++++
Есть у кого-нибудь на русском описание?
Старый 08.09.2011, 12:26   #11
Alexius is offline
Alexius
Аватар для Alexius
461 / 248 (9) ++++++
Если верить Планам разработки для России на июль 2011, то ее нет и не будет.
Внимание! Русскоязычная документация для пакета Rollup 7 не выпускалась в связи с тем, что пакет не содержит новой локальной функциональности, за исключением небольшого изменения описанного выше.
Последний раз редактировалось Poleax; 22.09.2011 в 11:04. Причина: + Цитата
ax2009, rollup, ru7
Часовой пояс GMT +3, время: 12:59.
