20.08.2008, 11:55 | #1 |
Microsoft Dynamics NAV 2009 has a new graphical object type called Charts or KPIs (Key Performance indicators). It is a way to create simple graphical charts, to give a visual overview of key figures. This post describes what you can and cannot do with charts, and it contains some sample code to how you might create a "Chart Generator Tool" to make it easier to generate new charts.
What you can and can't do with charts:
The layout of a chart: A chart has a simple layout. You choose the table to base it on, then a field from that table to show along the X-Axis, and - if needed - a filter on this table. Then you select what data from the table to show on the Y-Axis (also called Measure). A measure can be based on Sum or Count. You can display multiple measures in the same chart. This is what your charts could look like: Showing a chart: Charts can only be displayed in the new NAV 2009 client. To display a chart, follow these steps:
Removing a chart: You can personalize the page again to remove a chart, or click "Restore Defaults" to remove any personalization. You can also remove any personalization (including any charts that a user has added) with the classic client, from table 2000000075 "User Metadata". This is the table that stores the personalization for each page for each user. Deleting a record from this table removes any personalization made to that page by that user. Chart objects: Charts are stored in system table 2000000078 "Chart". You can view them with form 9182 Charts, or from Administration -> Application Setup -> Role Tailored Client -> Charts. Charts are defined by xml documents which are stored as BLOB fields. You can export a chart to an xml document, then modify the xml document, and import it back as a new chart. This is an example of a chart definition: The rules for the xml documents are:
Ideas for a Chart Generator Tool (CGT): Modifying xml documents can be tedious. But it can be made easier with tools. Below, I have put some sample NAV code, how such a tool could be made. Note !!!! === The code below is only supplied as an example of how such a tool could be made. It is completely un-supported and to be used at your own risk and responsibility. ==== The code below is provided in Text format. When importing text objects into NAV directly, you will not get any warnings whether to overwrite existing objects. So each object has been deliberately changed by adding [RemoveMe] in front of each Object ID. This would have to be removed, after reviewing each Object type and number, to check that it would not overwrite any existing objects! This is how the tool would work: the tool contains the following objects: Type ID Name 1 72000 Chart Generator 1 72001 Chart Generator Filter 1 72003 Chart Generator YAxis 2 72000 Chart Generator List 2 72001 Chart Filters 2 72003 YAxis List 2 72004 Chart Generator Card 5 72000 Chart Generator Mgt Charts can be generated from form 72004 "Chart Generator Card": Hit F3 to create a new chart. Enter ID and a Name. As a minimum you must specify Title, "Table ID", "X-Axis Field Name", and one or more Y-Axis fields. Once you have specified the chart definition, then click on Chart -> "Generate Chart". This will automatically either update an existing chart, or generate a new chart in table 2000000078, ready to be used from the new client. The following example shows how to create a chart to show Inventory for certain items:
Now the chart will be available for the new client as described above. If you update the chart, then the new client will use the new chart definition next time you restart it. These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use. Lars Lohndorf-Larsen Microsoft Dynamics UK Microsoft Customer Service and Support (CSS) EMEA === sample code only === OBJECT Table [RemoveMe]72000 Chart Generator { OBJECT-PROPERTIES { Date=19/08/08; Time=09:13:04; Modified=Yes; Version List=CGT; } PROPERTIES { OnInsert=BEGIN IF Chart.GET(Company,ID) THEN ERROR('Chart already exists in table 2000000078. Run form 9182 and delete it, or use a different ID.'); END; LookupFormID=Form72000; } FIELDS { { 1 ; ;Company ;Text30 } { 2 ; ;ID ;Code20 ;NotBlank=Yes } { 10 ; ;Name ;Text50 ;OnValidate=BEGIN Title := Name; END; } { 11 ; ;Title ;Text50 } { 15 ; ;Type ;Option ;OptionString=Column,Point } { 16 ; ;Table ID ;Integer ;OnValidate=BEGIN MODIFY; END; } { 17 ; ;Table Name ;Text30 ;FieldClass=FlowField; CalcFormula=Lookup(Object.Name WHERE (Type=CONST(Table), ID=FIELD(Table ID))); Editable=No } { 20 ; ;XAxis Field ID ;Integer } { 21 ; ;XAxis Field Name ;Text80 ;OnValidate=BEGIN IF "XAxis Field Name" <> '' THEN BEGIN FieldRec.SETRANGE(TableNo,"Table ID"); FieldRec.SETRANGE(FieldName,"XAxis Field Name"); FieldRec.FINDFIRST; "XAxis Field ID" := FieldRec."No."; "XAxis Field Name" := FieldRec.FieldName; "XAxis Field Caption" := FieldRec."Field Caption"; "XAxis title" := FieldRec."Field Caption"; END ELSE BEGIN "XAxis Field ID" := 0; "XAxis Field Name" := ''; "XAxis Field Caption" := ''; "XAxis title" := ''; END; END; } { 22 ; ;XAxis Field Caption ;Text80 } { 23 ; ;XAxis title ;Text80 } { 24 ; ;Show Title ;Boolean ;InitValue=Yes } { 30 ; ;YAxis fields ;Integer ;FieldClass=FlowField; CalcFormula=Count("Chart Generator YAxis" WHERE (Company=FIELD(Company), ID=FIELD(ID))); Editable=No } } KEYS { { ;Company,ID ;Clustered=Yes } } FIELDGROUPS { } CODE { VAR Chart@1000 : Record 2000000078; FieldRec@1102601000 : Record 2000000041; BEGIN END. } } OBJECT Table [RemoveMe]72001 Chart Generator Filter { OBJECT-PROPERTIES { Date=19/08/08; Time=16:44:37; Modified=Yes; Version List=CGT; } PROPERTIES { OnInsert=BEGIN TESTFIELD("Filter Field ID"); END; } FIELDS { { 1 ; ;Company ;Text30 } { 2 ; ;ID ;Code20 } { 3 ; ;Line No. ;Integer } { 10 ; ;Filter Field ID ;Integer ;OnValidate=BEGIN IF "Filter Field ID" <> 0 THEN BEGIN ChartGen.GET(Company,ID); ChartGen.TESTFIELD("Table ID"); FieldRec.GET(ChartGen."Table ID","Filter Field ID"); "Filter Field Name" := FieldRec.FieldName; END ELSE "Filter Field Name" := ''; END; } { 11 ; ;Filter Field Name ;Text30 } { 15 ; ;Filter Value ;Text30 } } KEYS { { ;Company,ID,Line No. ;Clustered=Yes } } FIELDGROUPS { } CODE { VAR ChartGen@1102601001 : Record 72000; FieldRec@1102601000 : Record 2000000041; BEGIN END. } } OBJECT Table [RemoveMe]72003 Chart Generator YAxis { OBJECT-PROPERTIES { Date=19/08/08; Time=07:26:24; Modified=Yes; Version List=CGT; } PROPERTIES { OnInsert=BEGIN TESTFIELD("YAxis Measure Field ID"); END; LookupFormID=Form72003; DrillDownFormID=Form72003; } FIELDS { { 1 ; ;Company ;Text30 } { 2 ; ;ID ;Code20 } { 3 ; ;Line No. ;Integer } { 10 ; ;YAxis Measure Field ID;Integer } { 11 ; ;YAxis Measure Field Caption;Text30 } { 12 ; ;Mearure Operator ;Option ;OptionString=Sum,Count } { 20 ; ;Show Title ;Boolean } } KEYS { { ;Company,ID,Line No. ;Clustered=Yes } } FIELDGROUPS { } CODE { BEGIN END. } } OBJECT Form [RemoveMe]72000 Chart Generator List { OBJECT-PROPERTIES { Date=12/08/08; Time=06:50:19; Modified=Yes; Version List=CGT; } PROPERTIES { Width=16500; Height=6710; TableBoxID=1; SourceTable=Table72000; } CONTROLS { { 1 ;TableBox ;220 ;220 ;16060;5500 ;HorzGlue=Both; VertGlue=Both } { 2 ;TextBox ;0 ;0 ;4400 ;0 ;HorzGlue=Both; Visible=No; ParentControl=1; InColumn=Yes; SourceExpr=Company } { 3 ;Label ;0 ;0 ;0 ;0 ;ParentControl=2; InColumnHeading=Yes } { 4 ;TextBox ;0 ;0 ;1700 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr=ID } { 5 ;Label ;0 ;0 ;0 ;0 ;ParentControl=4; InColumnHeading=Yes } { 6 ;TextBox ;0 ;0 ;4400 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr=Name } { 7 ;Label ;0 ;0 ;0 ;0 ;ParentControl=6; InColumnHeading=Yes } { 8 ;TextBox ;0 ;0 ;4400 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr=Title } { 9 ;Label ;0 ;0 ;0 ;0 ;ParentControl=8; InColumnHeading=Yes } { 10 ;TextBox ;0 ;0 ;550 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr=Type } { 11 ;Label ;0 ;0 ;0 ;0 ;ParentControl=10; InColumnHeading=Yes } { 12 ;TextBox ;0 ;0 ;1700 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr="Table ID" } { 13 ;Label ;0 ;0 ;0 ;0 ;ParentControl=12; InColumnHeading=Yes } { 14 ;CommandButton;4400 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; Default=Yes; PushAction=LookupOK; InvalidActionAppearance=Hide } { 15 ;CommandButton;6820 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; Cancel=Yes; PushAction=LookupCancel; InvalidActionAppearance=Hide } { 16 ;CommandButton;14080;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; PushAction=FormHelp } { 17 ;MenuButton ;9240 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; CaptionML=ENU=Chart; Menu=MENUITEMS { { ID=18; PushAction=RunObject; CaptionML=ENU=Filters; RunObject=Form 72001; RunFormLink=Company=FIELD(Company), ID=FIELD(ID) } { ID=20; PushAction=RunObject; CaptionML=ENU=XAxis; RunObject=Form 72002; RunFormLink=Field1=FIELD(Company), Field2=FIELD(ID) } { ID=21; PushAction=RunObject; CaptionML=ENU=YAxis; RunObject=Form 72003; RunFormLink=Company=FIELD(Company), ID=FIELD(ID) } } } { 19 ;MenuButton ;11660;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; CaptionML=ENU=F&unctions; Menu=MENUITEMS { { ID=22; PushAction=RunObject; ShortCutKey=F11; CaptionML=ENU=Generate Chart; RunObject=Codeunit 72000 } } } } CODE { VAR Chart@1000 : Record 2000000078; BEGIN END. } } OBJECT Form [RemoveMe]72001 Chart Filters { OBJECT-PROPERTIES { Date=19/08/08; Time=09:21:22; Modified=Yes; Version List=CGT; } PROPERTIES { Width=12150; Height=6710; TableBoxID=1; SourceTable=Table72001; AutoSplitKey=Yes; DelayedInsert=Yes; } CONTROLS { { 1 ;TableBox ;220 ;220 ;11710;5500 ;HorzGlue=Both; VertGlue=Both } { 2 ;TextBox ;0 ;0 ;1700 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr="Filter Field ID"; OnLookup=BEGIN ChartGen.GET(Company,ID); ChartGen.TESTFIELD("Table ID"); FieldRec.SETRANGE(TableNo,ChartGen."Table ID"); IF FORM.RUNMODAL(FORM::"Field List",FieldRec) = ACTION::LookupOK THEN VALIDATE("Filter Field ID",FieldRec."No."); END; } { 3 ;Label ;0 ;0 ;0 ;0 ;ParentControl=2; InColumnHeading=Yes } { 4 ;TextBox ;0 ;0 ;4400 ;0 ;HorzGlue=Both; ParentControl=1; InColumn=Yes; SourceExpr="Filter Field Name" } { 5 ;Label ;0 ;0 ;0 ;0 ;ParentControl=4; InColumnHeading=Yes } { 6 ;TextBox ;0 ;0 ;4400 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr="Filter Value" } { 7 ;Label ;0 ;0 ;0 ;0 ;ParentControl=6; InColumnHeading=Yes } { 8 ;CommandButton;4890 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; Default=Yes; PushAction=LookupOK; InvalidActionAppearance=Hide } { 9 ;CommandButton;7310 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; Cancel=Yes; PushAction=LookupCancel; InvalidActionAppearance=Hide } { 10 ;CommandButton;9730 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; PushAction=FormHelp } } CODE { VAR ChartGen@1000 : Record 72000; FieldRec@1001 : Record 2000000041; BEGIN END. } } OBJECT Form [RemoveMe]72003 YAxis List { OBJECT-PROPERTIES { Date=19/08/08; Time=07:31:05; Modified=Yes; Version List=CGT; } PROPERTIES { Width=10000; Height=6710; TableBoxID=1; SourceTable=Table72003; AutoSplitKey=Yes; DelayedInsert=Yes; } CONTROLS { { 1 ;TableBox ;220 ;220 ;9560 ;5500 ;HorzGlue=Both; VertGlue=Both } { 2 ;TextBox ;0 ;0 ;1700 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr="YAxis Measure Field ID"; OnLookup=BEGIN ChartGen.GET(Company,ID); ChartGen.TESTFIELD("Table ID"); FieldRec.SETRANGE(TableNo,ChartGen."Table ID"); IF FORM.RUNMODAL(FORM::"Field List",FieldRec) = ACTION::LookupOK THEN BEGIN "YAxis Measure Field ID" := FieldRec."No."; "YAxis Measure Field Caption" := FieldRec."Field Caption"; END; END; } { 3 ;Label ;0 ;0 ;0 ;0 ;ParentControl=2; InColumnHeading=Yes } { 4 ;TextBox ;0 ;0 ;4400 ;0 ;HorzGlue=Both; ParentControl=1; InColumn=Yes; SourceExpr="YAxis Measure Field Caption" } { 5 ;Label ;0 ;0 ;0 ;0 ;ParentControl=4; InColumnHeading=Yes } { 6 ;TextBox ;0 ;0 ;550 ;0 ;ParentControl=1; InColumn=Yes; SourceExpr="Mearure Operator" } { 7 ;Label ;0 ;0 ;0 ;0 ;ParentControl=6; InColumnHeading=Yes } { 8 ;CheckBox ;0 ;0 ;1700 ;0 ;ParentControl=1; InColumn=Yes; ShowCaption=No; SourceExpr="Show Title" } { 9 ;Label ;0 ;0 ;0 ;0 ;ParentControl=8; InColumnHeading=Yes } { 10 ;CommandButton;2740 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; Default=Yes; PushAction=LookupOK; InvalidActionAppearance=Hide } { 11 ;CommandButton;5160 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; Cancel=Yes; PushAction=LookupCancel; InvalidActionAppearance=Hide } { 12 ;CommandButton;7580 ;5940 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; PushAction=FormHelp } } CODE { VAR ChartGen@1000 : Record 72000; FieldRec@1001 : Record 2000000041; BEGIN END. } } OBJECT Form [RemoveMe]72004 Chart Generator Card { OBJECT-PROPERTIES { Date=19/08/08; Time=08:17:28; Modified=Yes; Version List=CGT; } PROPERTIES { Width=16170; Height=6490; SourceTable=Table72000; } CONTROLS { { 1 ;TabControl ;220 ;220 ;15730;5280 ;HorzGlue=Both; VertGlue=Both; PageNamesML=ENU=General } { 4 ;TextBox ;3850 ;990 ;2750 ;440 ;ParentControl=1; InPage=0; SourceExpr=ID } { 5 ;Label ;440 ;990 ;3300 ;440 ;ParentControl=4 } { 6 ;TextBox ;3850 ;1650 ;5500 ;440 ;ParentControl=1; InPage=0; NextControl=12; SourceExpr=Name } { 7 ;Label ;440 ;1650 ;3300 ;440 ;ParentControl=6 } { 8 ;TextBox ;3850 ;2200 ;5500 ;440 ;ParentControl=1; InPage=0; SourceExpr=Title } { 9 ;Label ;440 ;2200 ;3300 ;440 ;ParentControl=8 } { 10 ;TextBox ;3850 ;3520 ;2750 ;440 ;ParentControl=1; InPage=0; SourceExpr=Type } { 11 ;Label ;440 ;3520 ;3300 ;440 ;ParentControl=10 } { 12 ;TextBox ;3850 ;2860 ;1700 ;440 ;ParentControl=1; InPage=0; SourceExpr="Table ID"; OnLookup=BEGIN Object.SETRANGE(Type,Object.Type::Table); IF FORM.RUNMODAL(FORM::Objects,Object) = ACTION::LookupOK THEN "Table ID" := Object.ID; END; OnAfterValidate=BEGIN CALCFIELDS("Table Name"); END; } { 13 ;Label ;440 ;2860 ;3300 ;440 ;ParentControl=12 } { 21 ;TextBox ;12980;990 ;2750 ;440 ;ParentControl=1; InPage=0; NextControl=1102601000; SourceExpr="XAxis Field Name"; OnLookup=BEGIN TESTFIELD("Table ID"); FieldRec.SETRANGE(TableNo,"Table ID"); IF FORM.RUNMODAL(FORM::"Field List",FieldRec) = ACTION::LookupOK THEN VALIDATE("XAxis Field Name",FieldRec.FieldName); END; } { 22 ;Label ;9570 ;990 ;3300 ;440 ;ParentControl=21 } { 20 ;TextBox ;12980;1650 ;2750 ;440 ;ParentControl=1; InPage=0; SourceExpr="XAxis Field Caption" } { 23 ;Label ;9570 ;1650 ;3300 ;440 ;ParentControl=20 } { 24 ;CheckBox ;12980;2750 ;440 ;440 ;ParentControl=1; InPage=0; ShowCaption=No; SourceExpr="Show Title" } { 25 ;Label ;9570 ;2750 ;3300 ;440 ;ParentControl=24 } { 27 ;TextBox ;12980;2200 ;2750 ;440 ;ParentControl=1; InPage=0; SourceExpr="XAxis title" } { 28 ;Label ;9570 ;2200 ;3300 ;440 ;ParentControl=27 } { 1102601000;TextBox;12980;3410 ;1700 ;440 ;ParentControl=1; InPage=0; SourceExpr="YAxis fields" } { 1102601001;Label ;9570 ;3410 ;3300 ;440 ;ParentControl=1102601000 } { 1102601002;TextBox;5720 ;2860 ;3630 ;440 ;ParentControl=1; InPage=0; SourceExpr="Table Name" } { 14 ;CommandButton;13750;5720 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; PushAction=FormHelp } { 15 ;MenuButton ;11330;5720 ;2200 ;550 ;HorzGlue=Right; VertGlue=Bottom; CaptionML=ENU=&Chart; Menu=MENUITEMS { { ID=16; PushAction=LookupTable; ShortCutKey=F5; CaptionML=ENU=L&ist } { ID=26; PushAction=RunObject; CaptionML=ENU=Filters; RunObject=Form 72001; RunFormLink=Company=FIELD(Company), ID=FIELD(ID) } { ID=17; PushAction=RunObject; CaptionML=ENU=YAxis; RunObject=Form 72003; RunFormLink=Company=FIELD(Company), ID=FIELD(ID) } { ID=18; MenuItemType=Separator } { ID=19; PushAction=RunObject; ShortCutKey=F11; CaptionML=ENU=Generate Chart; RunObject=Codeunit 72000 } } } } CODE { VAR FieldRec@1001 : Record 2000000041; Object@1002 : Record 2000000001; XAxisField@1000 : Text[30]; BEGIN END. } } OBJECT Codeunit [RemoveMe]72000 Chart Generator Mgt { OBJECT-PROPERTIES { Date=19/08/08; Time=16:47:56; Modified=Yes; Version List=CGT; } PROPERTIES { TableNo=72000; OnRun=BEGIN CreateXML(Rec); MESSAGE('Chart %1 was created / updated.',Chart.ID); END; } CODE { VAR Chart@1015 : Record 2000000078; ChartGen@1003 : Record 72000; ChartFilters@1008 : Record 72001; ChartYAxis@1012 : Record 72003; "3TierMgt"@1013 : Codeunit 419; XMLDoc@1000 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 4.0:{F6D90F11-9C73-11D3-B32E-00C04F990BB4}:'Microsoft XML, v4.0'.DOMDocument"; DomNode@1001 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 4.0:{2933BF80-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v4.0'.IXMLDOMNode"; DomNode2@1006 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 4.0:{2933BF80-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v4.0'.IXMLDOMNode"; DomTextNode@1002 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 4.0:{2933BF87-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v4.0'.IXMLDOMText"; DomAttribute@1004 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 4.0:{2933BF85-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v4.0'.IXMLDOMAttribute"; DomNodeList@1009 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 4.0:{2933BF82-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v4.0'.IXMLDOMNodeList"; DomProcessInstruction@1005 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 4.0:{2933BF89-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v4.0'.IXMLDOMProcessingInstruction"; NameSpace@1007 : Text[80]; i@1010 : Integer; TempFileName@1014 : Text[250]; Debug@1016 : Boolean; DebugFileName@1102601000 : Text[250]; IStream@1102601001 : InStream; PROCEDURE CreateXML@1(ChartGenerator@1000 : Record 72000); BEGIN //=== Enable debug and filename to save the xml document to disk Debug := FALSE; DebugFileName := ''; //=== CREATE(XMLDoc); XMLDoc.async(FALSE); // Initialize document and set namespaces NameSpace := 'urn:schemas-microsoft-com:dynamics:NAV:MetaObjects'; DomNode := XMLDoc.createNode(1,'ChartDefinition',NameSpace); DomAttribute := XMLDoc.createAttribute('xmlns:xsd'); DomAttribute.value := 'http://www.w3.org/2001/XMLSchema'; DomNode.attributes.setNamedItem(DomAttribute); DomAttribute := XMLDoc.createAttribute('xmlns:xsi'); DomAttribute.value := 'http://www.w3.org/2001/XMLSchema-instance'; DomNode.attributes.setNamedItem(DomAttribute); // add chart type DomAttribute := XMLDoc.createAttribute('Type'); CASE ChartGenerator.Type OF ChartGenerator.Type::Column: DomAttribute.value := 'Column'; ChartGenerator.Type::Point: DomAttribute.value := 'Point'; END; DomNode.attributes.setNamedItem(DomAttribute); XMLDoc.appendChild(DomNode); AddNode('ChartDefinition','Title',''); AddNode('ChartDefinition/Title','Text',ChartGenerator.Title); AddAttribute('ChartDefinition/Title/Text','ID','ENU'); AddNode('ChartDefinition','Table',''); AddAttribute('ChartDefinition/Table','ID',FORMAT(ChartGenerator."Table ID")); AddNode('ChartDefinition/Table','Filters',''); // Filters ChartFilters.SETRANGE(Company,ChartGenerator.Company); ChartFilters.SETRANGE(ID,ChartGenerator.ID); IF ChartFilters.FINDSET THEN REPEAT AddNode('ChartDefinition/Table/Filters','Filter',''); AddNode('ChartDefinition/Table/Filters/Filter','Field',''); AddAttribute('ChartDefinition/Table/Filters/Filter/Field','Name',ChartFilters."Filter Field Name"); AddNode('ChartDefinition/Table/Filters/Filter','Value',ChartFilters."Filter Value"); UNTIL ChartFilters.NEXT = 0; // XAxis ChartGenerator.TESTFIELD("XAxis Field Name"); AddNode('ChartDefinition','XAxis',''); AddAttribute('ChartDefinition/XAxis','ShowTitle',BooleanFormat(ChartGenerator."Show Title")); /// AddNode('ChartDefinition/XAxis','Title',''); AddNode('ChartDefinition/XAxis/Title','Text',ChartGenerator."XAxis title"); AddAttribute('ChartDefinition/XAxis/Title/Text','ID','ENU'); AddNode('ChartDefinition/XAxis','Field',''); AddAttribute('ChartDefinition/XAxis/Field','Name',ChartGenerator."XAxis Field Name"); // YAxis ChartYAxis.SETRANGE(Company,ChartGenerator.Company); ChartYAxis.SETRANGE(ID,ChartGenerator.ID); IF ChartYAxis.FINDSET THEN BEGIN AddNode('ChartDefinition','YAxis',''); AddAttribute('ChartDefinition/YAxis','ShowTitle',BooleanFormat(ChartYAxis."Show Title")); AddNode('ChartDefinition/YAxis','Measures',''); REPEAT AddNode('ChartDefinition/YAxis/Measures','Measure',''); AddAttribute('ChartDefinition/YAxis/Measures/Measure','Operator',FORMAT(ChartYAxis."Mearure Operator")); AddNode('ChartDefinition/YAxis/Measures/Measure','Field',''); AddAttribute('ChartDefinition/YAxis/Measures/Measure/Field','Name',FORMAT(ChartYAxis."YAxis Measure Field Caption")); UNTIL ChartYAxis.NEXT = 0; END; TempFileName := TEMPORARYPATH + '' + FORMAT(CREATEGUID) + '.xml'; XMLDoc.save(TempFileName); IF NOT Chart.GET(ChartGenerator.Company,ChartGenerator.ID) THEN BEGIN Chart.Company := ChartGenerator.Company; Chart.ID := ChartGenerator.ID; Chart.Name := ChartGenerator.Name; Chart.INSERT; END; Chart.BLOB.IMPORT(TempFileName); Chart.MODIFY; IF Debug THEN XMLDoc.save(DebugFileName); // Clean up IF EXISTS(TempFileName) THEN ERASE(TempFileName); CLEAR(DomNode); CLEAR(XMLDoc); END; PROCEDURE AddNode@2(AddToNode@1000 : Text[120];NodeName@1001 : Text[120];NodeValue@1002 : Text[120]); BEGIN DomNodeList := XMLDoc.selectNodes(AddToNode); DomNode := DomNodeList.item(DomNodeList.length - 1); DomNode2 := XMLDoc.createNode(1,NodeName,NameSpace); DomTextNode := XMLDoc.createTextNode(NodeValue); DomNode2.appendChild(DomTextNode); DomNode.appendChild(DomNode2); END; PROCEDURE AddAttribute@3(AddToNode@1000 : Text[120];AttributeName@1001 : Text[120];AttributeValue@1002 : Text[120]); BEGIN DomNodeList := XMLDoc.selectNodes(AddToNode); DomNode := DomNodeList.item(DomNodeList.length - 1); DomAttribute := XMLDoc.createAttribute(AttributeName); DomAttribute.value := AttributeValue; DomNode.attributes.setNamedItem(DomAttribute); END; PROCEDURE BooleanFormat@4(Boo@1000 : Boolean) : Text[30]; BEGIN IF Boo THEN EXIT('true'); EXIT('false'); END; EVENT XMLDoc@1000:ndataavailable@198(); BEGIN END; EVENT XMLDoc@1000:nreadystatechange@-609(); BEGIN END; BEGIN END. } } Читать дальше
