24.09.2020, 10:14 | #1 |
butenko.pro: How to get type of the instance (production/sandbox/something else) using code
Источник: https://butenko.pro/2020/09/24/how-t...se-using-code/
============== I was working on the plugin where logic had to work differently depending on the type of the instance, i.e. if code is executed in Sandbox environment – do A, if code is executed in Production – do B. I never developed anything similar before and search engines did not bring anything valuable. After research ... Источник: https://butenko.pro/2020/09/24/how-t...se-using-code/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
