Вернуться   AXForum > BI > BI Blogs
Старый 14.01.2021, 08:16   #1
25,475 / 846 (79) +++++++
msdynamicsworld: Power BI Insights: HTTP endpoints; Audit Log; Excel refresh; Messy category data
Источник: https://msdynamicsworld.com/story/po...-category-data
Microsoft Power BI pros share their insights on HTTP endpoint querying, Audit Log, refreshing Excel files and cleaning up messy data.
HTTP endpoints and querying Azure Analysis Services and Power BI Premium
Chris Webb often wondered about running queries against Azure Analysis Services and Power BI with a REST API. He uncovered a project by David Browne at Microsoft, which is available on GitHub. The sample is an HTTP proxy geared toward XMLA endpoints.
Implemented as an ASP.NET Core 5 API project, it allows users to post DAX queries receiving results back as JSON. Oriented for pass-through authentication from the client to the XMLA endpoint, it also fetches a token with a resource ID for the XMLA endpoint as an added security feature.
<h2>Seeing REST API calls with the Audit Log
msdynamicsworld: Power BI Insights: Adding semesters; Custom icons; Naming conventions; Duplicating measures Blog bot DAX Blogs 0 19.03.2020 02:13
msdynamicsworld: Power BI Insights: 2019 in review; Power BI misconceptions; Activity Log; Report performance; Data culture Blog bot DAX Blogs 0 06.01.2020 19:13
msdynamicsworld: Microsoft Power BI Insights: AI transformation credentials; Analysis Services vs. PBI Premium; CPU management; Power Query troubleshooting; Querying Blog bot DAX Blogs 0 25.11.2019 07:11
msdynamicsworld: Power BI Insights: DAX filters; More uses of Power Query; Merging workbooks; Tracking ticket assignments Blog bot DAX Blogs 0 11.11.2019 09:11
Часовой пояс GMT +3, время: 03:06.
