Старый 15.11.2021, 18:27   #1
25,459 / 846 (79) +++++++
crmtipoftheday: Tip #1419: Dual-write 404 error when metadata contains special characters
Источник: https://crmtipoftheday.com/1419/dual...ial-characters
As Power Platform extends its reach beyond the realms of Dynamics 365 (CRM/CE/etc) and SharePoint, we’re starting to see some interesting integration challenges from Dataverse big brother – Finance and Operations. Today’s tip is from Parth Bhaidani. (Hey, you can have your name published here too – just drop your sizzling tip into jar@crmtipoftheday.com!)
Dual-write provides tightly coupled, bidirectional integration between Finance and Operations apps and Dataverse. However, at times it could be trickier to address the issues. Recently, I was working on a Dual-Write integration and one of the tasks was to add a new Table map. Prima facie the task was fairly straightforward until I stumbled upon the error, “The remote server returned an error: (404) Not Found. Unable to retrieve metadata for AX environment“. Turns out the name of the Table on the F&O side has a forward slash (/) in it (Country/regions) and that’s the reason for the error above.
To fix this issue, we would have to create a new Data Entity but without special characters. (Luckily, in F&O we can create multiple entities for the same underlying table – t.j.)
  1. In the F&O environment go to Data Management Workspace -> Data Entities
  2. Search the Table name for which you are trying to add the Table Mapping (in my case Country/regions) and copy the Target entity name.
  3. Click New and populate Target entity with the copied Target entity from the above step, everything else will be auto populated and leave those columns as is. Click Save.
  4. Add the Table Mapping using the new name (which is again the one copied in Step 2). Now, you should be able to add mapping without any issues.
Cover photo by Vincent van Zalinge on Unsplash
crmtipoftheday: Tip #1402: Why you should not use Microsoft Lists/SharePoint Lists for business-critical Power Apps Blog bot Dynamics CRM: Blogs 0 17.02.2021 15:12
crmtipoftheday: Tip #1346: Where to find Azure AD B2C Metadata endpoint for this policy Blog bot Dynamics CRM: Blogs 0 29.04.2020 16:12
msdynamicsworld: Microsoft prepares launch of Dynamics 365 dual-write for bi-directional ERP-CRM integration Blog bot DAX Blogs 0 30.03.2020 20:12
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Опции темы Поиск в этой теме
Поиск в этой теме:
Расширенный поиск
Опции просмотра
Часовой пояс GMT +3, время: 16:37.
