Старый 09.07.2012, 18:11   #1
25,488 / 846 (79) +++++++
axepclipboard: (Ax2009) Search through Web Controls
Источник: http://feedproxy.google.com/~r/AxEpC...3/yOpqch-dZls/
Since Dynamics Ax 2012 it is possible to search for code inside web controls by using the default AOT search functionality. In Dynamics Ax 2009 on the other hand, this is not an option. There is a way to do this, although it is not inside of Ax. Ax 2012 Ax 2009 The easiest way [...]
emeadaxsupport: Dynamics AX 2009 Enterprise Portal Web Controls are stored in USR instead of VAR Layer Blog bot DAX Blogs 0 21.09.2010 13:05
daxdilip: Dynamics AX 2009 Enterprise Portal Web Form Converter to Web User Controls Blog bot DAX Blogs 0 12.08.2010 11:05
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Часовой пояс GMT +3, время: 07:11.
