Старый 08.09.2020, 23:14   #1
25,475 / 846 (79) +++++++
crmtipoftheday: Tip #1381: Fixed reference entity in Power Automate
Источник: https://crmtipoftheday.com/1381/fixe...power-automate
Need to reference a fixed record, for example, Accounts Payables, or SARS-CoV-2? Challenge with fixed records is that we have no idea what the record identifier is, how to reliably search for the record and how to pass it as a parameter between environments.
Why not to use a fixed guid and create that entity when needed?
  1. Goto https://www.guidgenerator.com/ or any other guid generator of your choice.
  2. Generate a new guid. Don’t worry about duplicate detection. You have not seen that guid before, trust me.
  3. Get the record you’re after using that guid
    • restrict the attributes to what you need; if checking for the record presence and nothing else, put in just the primary key entitynameid.
  4. Create that record if failed
    • configure create action to run on fail
    • set record id to that guid you’ve created earlier
  5. Now you can safely use the reference in lookups etc.
Something like this:
Cover photo by Thorn Yang from Pexels
crmtipoftheday: Tip #1372: Synchronous Power Automate Flow on create/update of a record Blog bot Dynamics CRM: Blogs 0 30.06.2020 07:17
crmtipoftheday: Tip #1363: Get Environment Variables in Power Automate (and Power Apps) Blog bot Dynamics CRM: Blogs 0 09.06.2020 23:17
crmtipoftheday: Tip #1362: Trigger Power Automate on Associate / Disassociate Blog bot Dynamics CRM: Blogs 0 08.06.2020 14:11
crmtipoftheday: Tip #1359: Whose fault is it in Power Automate? Blog bot Dynamics CRM: Blogs 0 03.06.2020 11:11
Часовой пояс GMT +3, время: 19:10.
