Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 04.06.2012, 22:03   #1
Kent is offline
Kent
evalBuf()
Hi,
To use evalBuf() development permission is needed. Is some other kind of way, to evalute math string expressions? An example, ((5 + 7 -2) \ 6)
Старый 05.06.2012, 08:20   #2
kornix is offline
kornix
414 / 146 (5) +++++
Сообщение от Kent Посмотреть сообщение
Hi,
Hi! You can use runBuf() instead evalBuf function.
runbuf("Х1>Х2 ? 23/Х1 : Х2*3", X1, X2);
Старый 05.06.2012, 08:24   #3
S.Kuskov is offline
S.Kuskov
3,430 / 1772 (66) ++++++++
evalBuf, runBuf and xppCompiller have access to system functions, not only to mathematical calculations. Therefore, they require enhanced privileges
Solutions:
1. Use runAs() function to temporarily receive enhanced privileges.
2. Use external library or stored procedure
3. Write your own parser
4. RealEdit and IntEdit controls have native support of the calculation simple expression. Type this string "(5+7-2)/6" (without quotes) in the input field of these controls
Последний раз редактировалось S.Kuskov; 05.06.2012 в 08:26.
Старый 05.06.2012, 14:58   #4
Kent is offline
Kent
Thanks.
Acctualy if evalBuf() is usded in code to calculate given expression it works very well also without development privilegies.
Часовой пояс GMT +3, время: 14:58.
