Старый 29.05.2008, 15:58   #13
MFCшный Wizard is offline
MFCшный Wizard
Спасибо, что тратите свое время.
Вот исправила код
function GetAttributeValueByEntityId(entityName, entytiId, attributeName)
    var xml = '' + '<?xml version=\`1.0\` encoding=\`utf-8\`?>' + '\r\n' + '<soap:Envelope xmlns:soap=\`http://schemas.xmlsoap.org/soap/envelope/\` xmlns:xsi=\`http://www.w3.org/2001/XMLSchema-instance\` xmlns:xsd=\`http://www.w3.org/2001/XMLSchema\`>' + '\r\n' + ' <soap:Body>' + '\r\n' + ' <entityName xmlns=\`http://schemas.microsoft.com/crm/2006/WebServices\`>' + entityName + '</entityName>' + '\r\n' + ' <id xmlns=\`http://schemas.microsoft.com/crm/2006/WebServices\`>' + entytiId + '</id>' + '\r\n' + ' <columnSet xmlns=\`http://schemas.microsoft.com/crm/2006/WebServices\` xmlns:q=\`http://schemas.microsoft.com/crm/2006/Query\` xsi:type=\`q:ColumnSet\`>' + '\r\n' +  ' <q:Attributes>' + '\r\n' + ' <q:Attribute>' + attributeName + '</q:Attribute>' + '\r\n' + ' </q:Attributes>' + '\r\n' + ' </columnSet>' + '\r\n' + ' </soap:Body>' + '\r\n' + '</soap:Envelope>' +  '';
    xml = xml.replace(/\</gi, String.fromCharCode(60));
    xml = xml.replace(/\>/gi, String.fromCharCode(62));
    xml = xml.replace(/\\`/gi, String.fromCharCode(34));
    var xmlHttpRequest = new ActiveXObject('Msxml2.XMLHTTP');
//var xmlHttpRequest = new ActiveXObject('Microsoft.XMLHTTP');
   xmlHttpRequest.Open('POST', 'http://localhost:5555/mscrmservices/2006/CrmService.asmx', false);
    xmlHttpRequest.setRequestHeader('SOAPAction','http://schemas.microsoft.com/crm/2006/WebServices/Retrieve');
    xmlHttpRequest.setRequestHeader('Content-Type', 'text/xml; charset=utf-8');
    xmlHttpRequest.setRequestHeader('Content-Length', xml.length);
    xmlHttpRequest.send(xml);
    var doc = xmlHttpRequest.responseXML;
   alert(doc);
   alert(xmlHttpRequest.responseText);
    var retValue = '';
    if (doc.selectSingleNode('//RetrieveResult/' + attributeName) != null) retValue = doc.selectSingleNode('//RetrieveResult/' + attributeName).text;
    return retValue;
переделала и путь и кавычки
[ на <
Ошибка точно та же
Как получить значение поля одной сущности при обработке формы другой сущности zhenek Dynamics CRM: Разработка 25 05.07.2011 16:19
Присвоение одного атрибута сущности значения другого атрибута связанной сущности vital.mih Dynamics CRM: Функционал 38 08.09.2010 10:53
Как создать экземпляр кастомной сущности через SOAP? Tony Green Dynamics CRM: Разработка 7 27.02.2009 08:37
Создание объекта сущности из другого объекта! SnSS Dynamics CRM: Разработка 5 29.05.2008 13:38
Каким образом самопальный лукап привязывается к сущности? tatra Dynamics CRM: Разработка 4 25.09.2007 12:58
Часовой пояс GMT +3, время: 06:57.
